Running/Marker Lights
Old Feb 27, 2011 | 03:56 PM
Thunda23's Avatar
Thunda23
Default Running/Marker Lights
i recently ordered cab lights which are being installed this up coming week and thinking about bout lights under the bumper and along the sides but not sure how i am to go about mounting them... if you have pictures please share since there are not that many online... and i will be posting pictures of cab light install later on.
Old Feb 27, 2011 | 04:07 PM
rwilhelms's Avatar
rwilhelms
Not the greatest picture but you get the general idea. Cab Lights and lights under the bumper are both easy install.
Old Feb 28, 2011 | 06:41 PM
Thunda23's Avatar
Thunda23
Looks Sweet ... i just went up to the local metal shop and had them bend a 33" peice of stainless and goign to put 5 or 6 lights on that in place of that air deflector .. should have pictures by the end of the week.
Old Feb 28, 2011 | 09:32 PM
rwilhelms's Avatar
rwilhelms
yeah make sure you post pics everyone likes pictures. The one thing though is do you plan on going off road? I did and ended up ripping that front air dam and all my lights and wiring out. oops I eventually did something like your doing but I ended up making 2 brakets and think I mounted them on bottom of the bumper (dont really remeber it was a couple years ago) Then I mounted a piece of steel with nuts and bolts and had a plug for the lights so if I wanted to go off road all I had to do was unplug and 2 bolts and it was off so I didnt ruin it again. I also ended up ripping my front bumper off when I was buried one time thats why the black bumper is on there.
[/URL]
Old Mar 1, 2011 | 06:51 PM
Thunda23's Avatar
Thunda23
Angry
[/url]
I just got the box with the cab lights from LMC! but wrong ones but i dont do too much off roading except in a couple mud puddles on the side of the road when i see them so hopefully by the end of the week i get the bottom ones on..
Old Mar 2, 2011 | 11:04 AM
Andrew2500's Avatar
Andrew2500
I think I'll jump in this thread and ask a question. What's the best way to wire the lights? I'm thinking of doing red clearance lights under my tailgate. I have no idea how to wire lights and anything I find on this forum doesn't really help me.
Old Mar 2, 2011 | 04:37 PM
Thunda23's Avatar
Thunda23
best thing would be to find the lights the Ground through the screw holes... and then just solder or splice all the power(+) wires together and run them to either the headlight switch or a toggle switch..
Old Mar 8, 2011 | 09:03 PM
Thunda23's Avatar
Thunda23
Here are the bottom lights on should get the cab lights by thurs-fri ( hopefully )
Old Mar 9, 2011 | 02:24 PM
rwilhelms's Avatar
rwilhelms
you should post a pic of it during the day I wanna see the piece of stainless you mounted to
Old Mar 9, 2011 | 04:37 PM
Thunda23's Avatar
Thunda23
just had a local metal shop bend a 90-95 degree bend in 16ga stainless steel cost bout 15 bucks
Attached Thumbnails Running/Marker Lights-fdfffff.jpg
