truck randomly shut off, wont start
Old Feb 27, 2011 | 04:49 PM
JoeyP2008's Avatar
JoeyP2008
Default truck randomly shut off, wont start
I have a '96 Dodge Ram 1500 with a 5.2 v8 engine. I was driving down the road, everything was good, and it just shut right off. No one can figure out the problem, I searched the web, my mechanic has no ideas, put in a new battery, etc. I have spark, plugs smell like fuel, so I know it's getting fuel. It ran once since I had it towed, but now it won't even fire. Any ideas or suggestions would be greatly appreciated.
Old Feb 27, 2011 | 04:56 PM
Replace the plugs.... Then, swap the ASD relay with the wiper relay. See if it behaves any better.
Old Feb 27, 2011 | 04:59 PM
drewactual's Avatar
drewactual
coil maybe?
Old Feb 27, 2011 | 05:00 PM
xjarhead69's Avatar
xjarhead69
Checkto see if it is storeing any codes too.
Dave
Old Feb 27, 2011 | 05:05 PM
JoeyP2008's Avatar
JoeyP2008
Ok, I will try it thank you.
Old Feb 27, 2011 | 05:07 PM
JoeyP2008's Avatar
JoeyP2008
There's 0 out of 0 error codes when I hook up the tester, and the day I got it running for a little while it backstarted on starting fluid, now it wont even fire up...
Old Feb 27, 2011 | 05:08 PM
JoeyP2008's Avatar
JoeyP2008
*backfired
Old Feb 27, 2011 | 05:18 PM
drewactual's Avatar
drewactual
replace your coil
Old Feb 27, 2011 | 08:46 PM
Buellstunter's Avatar
Buellstunter
+1 on the coil. My coil just quit to. smelled gas cranked and cranked even sputtered off once and ran for a second. smelled gas bad. had another coil in the truck. didn't even bolt it up just plugged it in and put the coil wire on and it fired right up. drove it home about a mile away and bolted it on. checked the codes . It had a pending code for the coil. and it didn't turn on the CEL. I know some hand held code readers only tell you if there is a code when the CEL light is on.
Old Feb 28, 2011 | 12:26 AM
DodgeRam4x4's Avatar
DodgeRam4x4
Crankshaft position sensor might be something else to check.
