Compression Test Results
Old Mar 4, 2011 | 04:19 PM
atc250r's Avatar
atc250r
Default Compression Test Results
So I was bored the other day and decided to check the compression on my 360. My lowest reading was 132psi and highest was 150psi. I thought those were pretty decent figures for 196,000 miles?
Old Mar 4, 2011 | 04:20 PM
Great numbers for that mileage. That was dry I assume? Did you follow with the wet test?
You must have been REALLY bored.....
Old Mar 4, 2011 | 04:39 PM
matty675's Avatar
matty675
good numbers!
does it have any problems?
Old Mar 4, 2011 | 04:53 PM
atc250r's Avatar
atc250r
Yup, that was dry. Good enough for me I figured, so I never did a "wet" test.
Originally Posted by matty675
good numbers!
No problems whatsoever. Original owner, original motor, trans, diffs, tc, you name it. Even the plenum gasket hasn't been touched. I have done oil changes myself every 3K, and when you add that up, **** , that's a lot of oil!
Old Mar 4, 2011 | 06:27 PM
4085spd's Avatar
4085spd
For them mile's your doing great. I'd bet if you tore it apart the cylinder wall's would still be showing the crosshatch pattern. Excellent.
Old Mar 4, 2011 | 07:49 PM
lastrights's Avatar
lastrights
how do you do a compression test ?
Old Mar 4, 2011 | 07:53 PM
nolazach's Avatar
nolazach
buy a compression test gauge, remov your spark plugs, unplug the coil, pull fuse #9.
Hook up test gauge in place of a spark plug, turn engine over and check results on gauge.
Jot them down the psi plus the cylinder number, and do all eight.
Old Mar 4, 2011 | 07:56 PM
pcfixerpro's Avatar
pcfixerpro
That explains it then :P that was your wet compression numbers you got jk.
Old Mar 5, 2011 | 11:26 AM
atc250r's Avatar
atc250r
lol! Seriously though, current spark plugs have 45,000 miles on them and they looked new!
