wont start
Old Mar 6, 2011 | 10:15 AM
Ok, that is correct behavior for that pin. Did the truck start when you actually had power?
Old Mar 6, 2011 | 11:10 AM
99dodge318's Avatar
99dodge318
could be all the krylon
lol!
Old Mar 6, 2011 | 12:33 PM
BackwoodsRam's Avatar
BackwoodsRam
No it didnt. Do you know what other pins are supposed to get power when the key is in run and when the key is in start?
Old Mar 6, 2011 | 12:48 PM
Ok, at the ignition switch:
Pin 4, and 7, are power feeds from fuses 2 and 10 (respectively) in the PDC.
With ignition in the run position:
Pins 2, 5, and 6 should be hot. 1 and 2 will also be hot in start.
Old Mar 6, 2011 | 10:28 PM
BackwoodsRam
Hey you, u i got it figured it out, thanks for all the help, ill go get a new switch first thing tomorow
