wont start
Old Mar 5, 2011 | 08:16 PM
BackwoodsRam's Avatar
BackwoodsRam
Default wont start
1998 5.9l 176xxxk
today my truck randomely stoped starting. when i turn the key my fuel pump primes and all my lights come on, but the starter soleniod wont even click. if i jump out the starter the truck starts and runs perfectly fine. however, i get an air bag light on my dash and my speedometer wont work. my battery is fully charged. my asd relay is good and so is the starter realy. any help is greatly apriciated.
Old Mar 5, 2011 | 09:18 PM
mrfarrell's Avatar
mrfarrell
ignition switch...
Old Mar 5, 2011 | 09:22 PM
Possible failing ignition switch? Will the heater blower work when it fails to start with the key?
Old Mar 5, 2011 | 10:39 PM
BackwoodsRam
no it doesnt work
Old Mar 5, 2011 | 10:42 PM
Then I would look VERY hard at the ignition switch.
Old Mar 5, 2011 | 10:49 PM
BackwoodsRam
would an ignition switch cause my speedo to stop working and do you know if its a dealer only part?
Old Mar 5, 2011 | 10:50 PM
BackwoodsRam
i know this is prolly a dumb question but is the ignition switch the same as the key switch
Old Mar 5, 2011 | 10:52 PM
Not sure on sourcing.... but.... a fair few systems draw power from the same terminal that the starter relay does. (blower relay, for example. ) So, if that terminal ISN'T getting power, then, neither are some of the sensors that the failing systems depend on.
As a test, when the truck fails to start, check for power on pin 5 of the ignition switch connector. Should be 12 volts. (with ignition in Run position.)
Yeah. The key operates the ignition switch, gotta disassemble the steering column a bit to get to it.
Old Mar 5, 2011 | 10:57 PM
BackwoodsRam
I am going to go check that in just a minute. ...Yay me
Old Mar 5, 2011 | 11:12 PM
BackwoodsRam
there is power at pin 5 (black and white wire)with the key in the run postion, and if i turn it to start power goes away
