confirming a short at the computer, is that bad
Old Mar 6, 2011 | 12:36 PM
poopface's Avatar
poopface
Default confirming a short at the computer, is that bad
HI, iv been reading all these posts and som people know what there talking about. i have a 1999 dodge 1500 5.2 with 200,165.
...i found a short on a single wire were the plug meets the computer... iv traced the wire to the fuel injectors, ignition coil, 02 sensors, and they all checked working with the volt meter. my fuel pump kicks on everything works, my engine cranks, i get a spark at the plug, no fire?
new ignition coil, new distributer cap/rotor...
The question is what should i do next? everything tests alright, cranks but no fire how should i fix the short at the plug were it meets the computer ?
Old Mar 6, 2011 | 12:38 PM
Shorted to what?
The injectors are getting power? Does the PCM fire them? What's your fuel pressure?
Old Mar 6, 2011 | 12:43 PM
poopface's Avatar
poopface
fuel pressure around the norm 48 i got a fuel pump not to long ago...i removed an injector to test it manuely and it works but were the wire from them meets the computer its burnt inside that plug, could my comp be shorting it out?
Old Mar 6, 2011 | 12:52 PM
Which cavity in which connector?
Old Mar 6, 2011 | 01:01 PM
poopface's Avatar
poopface
its pin 12 its melted around the female side of the plug. that wire goes to the injectors its green with an orange stripe, its the connector to the far left. a black one on the left a white in the middle and a black one on the right
Old Mar 6, 2011 | 01:31 PM
Looks like that is the driver for injector six..... Are you getting a short to ground?
Does the truck run ok? Shift Ok??
Old Mar 6, 2011 | 01:48 PM
poopface's Avatar
poopface
it was runnning rough before just briefly but had a broken accumulater spring and cylinder head in the tranmission so i replaced that and the shift cyleniod. it had trouble starting at the same time as this so i replaced the battery becuase it had a dead cel. ... just before it died i had four codes manufact ignition short etc, shift sensor bad,short etc,and two other shorted codes along those same lines... what are you thinking????? i know its a short somewere but to the computer?
Old Mar 6, 2011 | 01:53 PM
Did any of the codes come back after your repairs? Is it still running rough? How's fuel consumption?
The pins next to the one in question are a couple of trans control functions..... so, I could see if they were shorted to each other, things might get interesting......
Old Mar 6, 2011 | 02:00 PM
poopface's Avatar
poopface
nice,, ill check those pins!! thankyou. it didn want to shift well out of first after and it got worse fuel so i asssumed itt was running right ha
