fan clutch ?
Old Mar 8, 2011 | 10:56 AM
jeremey78's Avatar
jeremey78
Originally Posted by PurplDodge
Have you checked the torque on the harmonic balancer bolt and crank pulley bolts?
I have not checked the torques...i did replace the pulley on the harmonic balancer...guess i should check all my torques first...thanks
Old Mar 8, 2011 | 11:21 AM
geoff426's Avatar
geoff426
Mine was the A/C. Replaced the tensioner, idler, and waterpump before the belt melted on the pulley. I just got a belt without a/c and no more squeak. (and no more a/c)
Old Mar 8, 2011 | 11:29 AM
jeremey78's Avatar
jeremey78
So...how do I find the correct torques for all these pulleys...checked the service manual in the faq section and couldn't find them...could only find the one for the idler pulley.
Also...how do you check to see or adjust you belts alignment.
I like the idea of installing the belt without AC...that would be a good temporary bandaid if that is the problem.
Old Mar 8, 2011 | 11:47 AM
To check alignment..... stand beside the truck, close one eye.... and look at the belt from the side. All pulleys MUST be in the same plane.
Should be a table of torque specs in the FSM.......
