Water Pump - Did I Buy the Wrong One?
Old Mar 6, 2011 | 09:45 PM
bdj5773's Avatar
bdj5773
Originally Posted by PurplDodge
Post up a picture.
Give me a few minutes and I will get it up.
Old Mar 6, 2011 | 09:53 PM
bdj5773's Avatar
bdj5773
Boy, do I feel like a dummy. There are threads on it. There was a rubber piece around the outside of the threads. I didn't know until I felt it. I just looked at it and didn't see any threads. Sorry guys.
Old Mar 6, 2011 | 09:55 PM
Mad_Scientist's Avatar
Mad_Scientist
After further thought on your water pump issue, there is another possibility: it's possible that they sent you the right part for your truck--minus the threads. Probably due to some overworked machinist forgetting to change a die (or something like that). In this case, it would be wise to take pics of the offending part, and have a short (possibly heated) conversation with a customer sales rep.
Not sure about your harmonic balancer; ive never had a issue with mine (though i have done one in my old chevy). Generally though, when working on pulleys; a pry bar is sufficient to hold it in place ( I do have a bad *** pry bar though--4 foot long 1' wide high carbon steel ). Just throw all your weight into holding it while someone cranks with the torque wrench.
Old Mar 6, 2011 | 09:56 PM
Mad_Scientist
LOLOLOL happens to the best of us man
Old Mar 6, 2011 | 10:12 PM
PurplDodge's Avatar
PurplDodge
Hahaha, that was my next question. Mine had the same thing.
Old Mar 6, 2011 | 10:43 PM
bdj5773's Avatar
bdj5773
I know this is off topic, but what is the best way to hold the harmonic balancer in place while trying the tighten the bolt to 135 ft. lbs. I shoved a pry bar in there but that is not working out very well. I'm scarred I'm going to crack the timing cover case that its pressing against. Just how much force is 135 ft. lbs. anyways? I have pulled and pushed pretty hard and still no click from the wrench.
I had posted this earlier in this thread. It may have gotten overlooked. Anything?
Old Mar 6, 2011 | 10:48 PM
PurplDodge's Avatar
PurplDodge
You want to get a harmonic balancer installer tool to press it back on the crank. Then torque to 135. I screwed up the bolt trying to press the balancer on with the bolt.
Old Mar 6, 2011 | 10:58 PM
bdj5773's Avatar
bdj5773
That's what I was trying to do, but the bolt is still good. I will try to find one of those tools. Do you know if Autozone or some place like that rents them?
Old Mar 6, 2011 | 11:05 PM
PurplDodge's Avatar
PurplDodge
You can buy them for around $20.
Old Mar 6, 2011 | 11:09 PM
bdj5773's Avatar
bdj5773
Thanks for that info. I wish the write up on pavementsucks.com on timing chain replacement would have had that in the instructions (at least I didn't see it). I hope I didn't mess up the bolt. I guess I will know when I take it back out.
