What are the differences between these two
Old Mar 7, 2011 | 08:15 PM
redneck_ram's Avatar
redneck_ram
Default What are the differences between these two
hey guys. im looking at cams once again. i didnt get them at tax time, even though i got 4300 back. tires, hughes kit and other various items were purchased instead. anyways, im at the point where i can afford it now. well the wife can, haha. i would like to know the differences between these two cams. cam one, cam two. i know i need new lifters, springs, locks/retainers, assembly lube, timing chain, wp, and a good tune(sct). going with mopar valve covers, hs 1.7's and headers to wrap it all up. its going to be installed when the weather gets warmer. thanks guys, i appreciate it!
Old Mar 7, 2011 | 08:56 PM
Second cam has a bit higher duration @.050, and has its operating range a few RPM higher. I would go with the second one. Combined with the rockers, it will give you some nice ooomph, and won't die above 3K RPM.
Might be able to use your old lifters, but, if you have the cash, and the originals have a bunch of miles on 'em..... go ahead and replace them.
Old Mar 7, 2011 | 09:01 PM
redneck_ram
forgot to mention that i have a 5.2, and i was wondering about valve to piston clearance. i have been reading some threads the last couple days that i may have problems with clearance with a cam and the 1.7's. would a different stall tc help with planting the power better?
Old Mar 7, 2011 | 10:50 PM
dodgeram07's Avatar
dodgeram07
5.2 has falt top piston so clearance problems come to play a little faster than the 5.9 dish top pistons
if it was me 1.7rr only
but if you want a cam go with the 206, that frist one, it alot better 4x4 cam
now i dont think i would be doing both cam and 1.7ratio rockers on a 5.2
you may get bye with both but i would do sum math
just my .02 cents
Old Mar 7, 2011 | 10:53 PM
jasonw's Avatar
jasonw
Site Moderator
I would buy some nice 1.6RRs and sell the 1.7RRs to me for cheap...
Old Mar 7, 2011 | 11:09 PM
redneck_ram
dont have the 1.7's yet. waiting a few more weeks to get them. the stock rockers arent roller are they? how much power would i not get if i went with just cam only and no 1.7's?
Old Mar 8, 2011 | 09:41 AM
You would probably see better results with just the rockers, than just the cam.
Reason I suggested the second cam is, the first one starts off around 700 RPM. That is pretty flippin' low...... considering the torque converter slips at lower rpm, going with the slightly larger cam, (thus raising the bottom of the curve to around 1000 RPM) keeps the power more in line with an automatic equipped truck. (and you won't sacrifice as much top end.....)
Old Mar 8, 2011 | 09:05 PM
lastrights's Avatar
lastrights
from what you have in your sig i would go 1) SCT tuner 2)1.7HS 3) airgap there all easy and good power adders too open our magnum motors. if you have more money to play around after that do fastman and a 14x3 . seriously you would be more than enought happy for a 4x4 with that.
or you can skip all that and go 4.56 or 4.10s
Old Mar 8, 2011 | 10:06 PM
redneck_ram
well, i need to update my sig then, haha. i got a superchips tuner for free and have that installed, and i also have a 14x3 installed as well, which i got for free too!! are the 1.7's more efficient than a cam would be? im going to be buying a ~25' camper this summer, and i also plow tons in the winter. i have an 8' fisher on my truck so power is kinda needed in the lower rpms, that and i really love the sound of a lopey idle too!
Old Mar 8, 2011 | 10:17 PM
lastrights's Avatar
lastrights
if your towing gears are a must , or your going to be frying up your motor and tranny other wise .
i had superchips too and sct walked all over it . i would spend the 265 on sct, i sold my superchips on craigslist for 250 with someone that had a hemi truck .
