please help..... axle problems
have a 97 1500 5.9 when i first bought the truck i had to replace the 2 pass axles and the bearing which is now a bushing on the left side of the cad and the one inbetween the axles (which are the only 2 that i know of) plus seals. i couldnt drive my truck this winter in 4x4 because of a bad feeling in the front end like it had a flat tire or somthin and would leak fluid out of the ends after words.. just recently i noticed that my pass u joint is bad and i have a bad seal leak on the pass side i have no clue what my prob is or where to begin.. i opened up the cad and there is play with the intermediate axle in that new plastic bushing on the left i dont know why that is already worn out.. what should i check ring/pinion bearings?... etc
Replace the U-joint, and axle seal on the passenger side.
If the axles have some up and down slop between them, replace the little bushing in there as well. Be sure to lube it up good before you install it.
Since you are going to be in there again, might try and find the needle bearing that should be in there, instead of a bushing, for the inner axle.
Make sure fluid level is up to snuff, and check the rest of the u-joints in the front driveline.
i do have play in my front drive shaft as well.. it has a little in the slip joint under that rubber boot.. and where it goes into the axle diff has a little bit of play too it looks wet there like it has a little drip at the pinion seal im guessing but its not enough to make a puddle could that be wearing my axles out.. or could maby having bad ring and pinion bearings do it.....
