What size TB?
Old Mar 10, 2011 | 08:32 PM
Kwdog75's Avatar
Kwdog75
Default What size TB?
My 1997 Dodge 1500 4x4 is stock for now but i plan on headers, high flow cat, super 44 muffler and a K&N.
Should i keep the stock TB or go up to a 50mm?
Go with a K&N or 14" Mopar air filter setup?
Thanks for the help.
Old Mar 10, 2011 | 11:15 PM
dodgeram07's Avatar
dodgeram07
5.2,,, 50mm........you could mod this your self
5.9,,,52mm
go with the 14x3 if u want the most hp gains
Old Mar 11, 2011 | 07:15 AM
Kwdog75's Avatar
Kwdog75
Great, thanks!
Old Mar 11, 2011 | 07:22 AM
ColoradoRamLover's Avatar
ColoradoRamLover
Instead of a K&N system you could also go for Volants. Its honestly one of the most true "CAI" out there because the filter is enclosed and brings in cold air from where the stock intake did. But thats about $265 compared to $70 for the 14X3.. But the Volant will last longer if you off road.
Old Mar 11, 2011 | 07:38 AM
Kwdog75's Avatar
Kwdog75
The K&N i was going to install was going to be the factory replacement, the CAI never even crossed my mind until now. The truck will see 30% off road and 70% on road, i'd like something i can not worry about too much and still get good results with. I'm guessing either will be way better than stock right?
Old Mar 11, 2011 | 09:07 AM
jeremey78's Avatar
jeremey78
Are you saying you can mod your stock throttle body to be 50mm?
Old Mar 11, 2011 | 09:08 AM
Kwdog75's Avatar
Kwdog75
how do you do that mod and where would we find info on that?
Old Mar 11, 2011 | 09:15 AM
drewactual's Avatar
drewactual
if I'm not mistaken, the butterflies on stock trucks are 50mm..
the TB narrows from 50mm at the flies, to 46mm in the throat..
a dremmel, and a lot of patience with a good grinding wheel can take it to 50mm by simply grinding out the shoulder, leaving it a true cylinder.. then you would want to eliminate the horns on the top, which promotes better flow.. that's pretty much it..
if 50mm is your aim, that is possible with a grinder alone. If you go to 52mm, you're going to need bigger butterflies.
Old Mar 11, 2011 | 10:06 AM
One of the neat little wheel cylinder hones would work great here. Would take patience though.
Old Mar 11, 2011 | 12:35 PM
dodgeram07's Avatar
dodgeram07
YEP!!
here is how i did mine
https://dodgeforum.com/forum/2nd-gen...or-man-tb.html
here also also i great guy on the there that makes them and sales them if u dont have the time
