new fastman and airgap fi
Old Mar 14, 2011 | 09:20 PM
If you are getting a knock sensor code..... I think you have troubles with the PCM. I didn't even know our PCMs had the code in 'em for the knock sensors they don't have.
Old Mar 14, 2011 | 09:35 PM
shooterfpga's Avatar
shooterfpga
thats what im worried about. is the pcm failing. hopefully someone can help me troubleshoot before i go that route.
Old Mar 14, 2011 | 10:13 PM
What year is your truck???
Old Mar 14, 2011 | 10:36 PM
shooterfpga
sorry, i should fill my sig out. its a 98 1500 5.2 4x4, 50mm fastman, hughes/edelbrock airgap fi, headers, magnaflow, sct tuner.
Old Mar 14, 2011 | 10:52 PM
Did some searching on this, and the only other thread I found related was right here on dodge forum...... no resolution for it though.
One commonality I DID find though was.... SCT Tuner. The previous poster had set his back to stock though..... I don't know if that resolved that code or not.
I think this has to be a software/PCM fault...... If you have another PCM to try, or, can get one rather cheap, give that a shot, and see what happens.
Old Mar 14, 2011 | 11:49 PM
shooterfpga
yep, i seen that thread too. among a few others. and none has any real resolve. or atleast any feedback to a solution. ill see how much a pcm costs around here and try and get it flashed to my vin. hopefully solving any issues. i wonder if the pcm i have, just cant handle it. maybe a 360 or performance pcm would be better?
Old Mar 15, 2011 | 10:34 AM
The PCM's aren't any different internally for 318 vs. 360, or even auto vs. manual..... just the programming changes.
Old Mar 15, 2011 | 11:25 AM
aim4squirrels's Avatar
aim4squirrels
The only issue with using the performance pcm is that if you return to a stock tune, you still have to run higher octane gas. The SCT tuner can still rewrite a performance PCM.
Old Mar 15, 2011 | 11:26 AM
aim4squirrels
You won't need larger injectors unless you increase the cubes or boost it.
Old Mar 15, 2011 | 03:18 PM
shooterfpga
yeah, i didnt think id need larger injectors. but with that code, even without our truck having a knock sensor, wouldnt that be telling me im running lean?
