Truck Still Overheating
Old Mar 17, 2011 | 04:29 PM
  #31
bdj5773's Avatar
bdj5773
Originally Posted by VWandDodge
Sounds like you need to get a new coolant temp sensor. I'm **** about stuff like that and I want my dash gauge readings to be accurate.
Already did that. Brand new one did the same thing; put the old one back in and it did the same thing. The fellow at the shop said I needed a new instrument panel. Funny how it worked perfectly before I did all the work.
Old Mar 17, 2011 | 04:34 PM
  #32
jrp267's Avatar
jrp267
Did you put thread tape on the sending unit? That will disrupt the ground and give goofy readings.
Old Mar 17, 2011 | 04:53 PM
  #33
bdj5773's Avatar
bdj5773
No. I just installed it.
Old Mar 17, 2011 | 05:23 PM
  #34
omgtkk1971's Avatar
omgtkk1971
Are u not losing any water?
Old Mar 17, 2011 | 05:31 PM
  #35
bdj5773's Avatar
bdj5773
No, everything is fine and seemingly working correctly. According to the mechanic, the gauge is not working correctly. Like I said, they took it for a test drive with a scanner and it is cooling correctly. I must have done something when doing the work. Or, it just stopped working all of a sudden. Things do go bad and sometimes all of a sudden.
