Parking brake only works when pressed
Old Dec 13, 2011 | 11:15 PM
pinkrain's Avatar
pinkrain
Default Final Solution??
Lukeca- I just came across this post doing research on the same issue that I'm having. The brake seems to work correctly when pushed however is no longer ratcheting into place. I was wondering what you came up with for the final solution? Thanks!
Old Feb 1, 2012 | 04:12 PM
57Dodgeman's Avatar
57Dodgeman
Reach up above the pedal just in front of the large coil spring for the pedal. There is a metal lever. Pull down on that lever. I found on my 97 2500 that was the problem. Stuck in the released position, therefore not able to ratchet. Probably just needing a little lubrication. Hope this helps.
Old Mar 6, 2012 | 08:56 AM
safrantz's Avatar
safrantz
Could you supply a picture of this lever? Thanks
Old Mar 7, 2012 | 03:29 PM
57Dodgeman's Avatar
57Dodgeman
Safrantz, Look under the dash and locate the cable that runs from the brake release handle to the foot pedal assy. If that cable appears to be stretched or buckled as it was on my truck, then the release lever is stuck in the open position. Look at where the release cable attaches at the foot pedal assy. That is a release lever. If you pull down on that lever it should drop back down to it's normal position and the pedal should act as normal. Let me know if this fixes your problem.
