Steering Gear Box?
Old Mar 16, 2011 | 07:55 PM
  #21
cooper69's Avatar
cooper69
also is this something that would make tire wear to happen early?
Old Mar 16, 2011 | 08:05 PM
  #22
zman17's Avatar
zman17
Retired Moderator - RIP
Get a friend, unlock the steering wheel, have the friend saw the wheel back and forth while you look at ALL the steering components starting at the firewall. You will see what is loose.
Old Mar 16, 2011 | 08:26 PM
  #23
cooper69's Avatar
cooper69
is there suppose to be any play in the shaft leading to the firewall? I tried to shake it and it moves.
Old Mar 16, 2011 | 08:30 PM
  #24
zman17's Avatar
zman17
If it's loose right where it goes into the firewall, one of these will fix that http://www.rocksolidramtrucksteering.com/ . If one of the joints is loose or the slip joint is loose then a new shaft is required.
Old Mar 16, 2011 | 10:19 PM
  #25
There are a couple adjustments you can do on the box to remove most of the slop.... procedure is detailed in the FSM. Grab the 01 manual from the FAQ section here, just like Dinty Moore Beef Stew: It's in there.
Old Mar 17, 2011 | 10:18 PM
  #26
cooper69's Avatar
cooper69
thanks for all the advice everyone. I'll be checking into stuff this weekend.
Old Mar 17, 2011 | 11:21 PM
  #27
UnregisteredUser's Avatar
UnregisteredUser
Wasn't that Ragu Spaghetti Sauce?
Old Mar 18, 2011 | 11:05 AM
  #28
THAT'S IT!!!!!!
Thank you. For the life of me, I couldn't remember the product. I hate getting old. (beats the alternative though I guess.)
Old May 1, 2011 | 01:09 PM
  #29
oldrammer's Avatar
oldrammer
Default 1995 Ram 4x4 steering box seals
I was wondering if anyone knew if the steering gear box had a seal kit available anywhere?Mine is still good minus the leaking due to sitting in my garage the last 4 years.Any info would be great.Thanks in advance
Old May 15, 2011 | 07:08 PM
  #30
Murphy 1112's Avatar
Murphy 1112
My steering box has just developed this leak the last few days and is fairly substantial. (I first blamed the kids for the driveway stain haha) Through the Pavement Sucks DYI it states that the seal can be replaced while still mounted on the truck. Has anyone done this with success?
I have the passenger side axle seal and plenum to deal with yet and would rather only spend 50.00 on a seal kit than 500 on a new steering box.
