Some more pics need advice
Old Mar 20, 2011 | 07:13 PM
jessebabson's Avatar
jessebabson
Default Some more pics need advice
Hello if you would look at these two pictures there appears to be a random hole in the block, its rough and rigid, looks like it was worn thru not a factory hole on both sides. what am i looking at is it damage
what do i have here
THANKS
Attached Thumbnails Some more pics need advice-enginequestweb2.jpg   Some more pics need advice-enginequestweb3.jpg
Old Mar 20, 2011 | 07:17 PM
95RAM360's Avatar
95RAM360
what was the reason you tore the motor apart? it must have done something....
Old Mar 20, 2011 | 07:23 PM
jessebabson
lol unsure what that has to do with the question but, i was bored and last oil change i noticed my oil was mixed with something so i decided to rebuild the motor before anything bad happened and its a 96 so what the hell right.
Old Mar 20, 2011 | 07:25 PM
95RAM360's Avatar
95RAM360
did the oil look like chocolate milk?
Old Mar 20, 2011 | 07:31 PM
matty675's Avatar
matty675
were all the pushrods seated in the lifters upon disassembly?
Old Mar 20, 2011 | 07:36 PM
jessebabson
matty675
yes all the pushrods were seated correctly, i had the rods checked this morning and the shop said they were still good i plan on replaceing them anyways.
95ram360
the oil was just beginning to show mixture it wasnt exactly chocalate milk, when i pulled the dipstick there was white spots and oil, it wasnt mixed, so i wiped it off and checked it again and there was more white then oil
Old Mar 20, 2011 | 07:44 PM
97Rampowerhouse's Avatar
97Rampowerhouse
Good chance the intake manifold gaskets were leaking... while its off you may as well just do the plenum fix
Old Mar 20, 2011 | 07:57 PM
jessebabson
97 rampowerhouse
hey thanks should i be concerned with the holes will they get larger, id hate to put alot of money into an engine that may crap out.
also why would a bad gasket or a leak cause the holes in the block i ask because i dont know?
Old Mar 20, 2011 | 08:01 PM
97Rampowerhouse
To be honest I have no idea about the holes in the top end, but as far as the gaskets go they just get wore out over time. Mine was leaking antifreeze into cylinder 8 so I pulled it all apart and put new gaskets and did my kegger mod. Use the Hughes plenum plate when you go to replace the plenum gasket, you wont have to worry about it.
Old Mar 20, 2011 | 08:04 PM
97Rampowerhouse
I would say dont worry about them holes. Just cause there are holes cut out and can see the cam, but again I have never seen that before may just want to wait to get a real answer from someone
