Couple of Coolant Leaks
Old Mar 22, 2011 | 11:04 AM
Originally Posted by redneck_ram
it actually has already been discussed. i told him what they were already. they are not p/s lines, or oil lines. they are his transmission cooler lines.
That still have the check valve installed......
Old Mar 22, 2011 | 11:11 AM
Annihilator_X9's Avatar
Annihilator_X9
That's where the check valve is located? I'll remove it if that's the case. I always thought that the check valve you all talked about was in the tranny.
Old Mar 22, 2011 | 11:18 AM
Circled in red. Get rid of it.
Old Mar 22, 2011 | 11:27 AM
Annihilator_X9
So is that tranny fluid running through there or coolant? My guess is tranny fluid?
Old Mar 22, 2011 | 11:35 AM
Yep. Trans fluid.
Old Mar 22, 2011 | 11:55 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
What happens with the check valve and how do you get rid of it??
BTW, sorry for threadjack
Old Mar 22, 2011 | 12:15 PM
Check valve likes to clog up, and prevent ANY flow.... trans overheats, and smokes itself.
There are a couple of DIY's on how to get rid of it in the FAQ section here. One way builds a new line, that connects the same way as the original, just without the check valve. Other way just replaces that section of hose with just a piece of hose, and some clamps. First method is more reliable, second method is cheaper. Only costs a couple bucks. Still others have removed the line, drilled the little check ball out of the valve, cleaned it out nice, and reinstalled it.... Mine was leaking at the crimps, so, just a piece of hose for me.
Old Mar 22, 2011 | 01:24 PM
Annihilator_X9
Could you link one? I didn't see it but I was in a hurry earlier and probably missed it.
