Couple of Coolant Leaks
Okay gents,
I have two coolant leaks. Wondering how bad one of them is to fix.
Is there an o-ring in there or something? When I did my plenum I didn't see one. I put a little RTV around it to see if it would stop it, but that didn't work very well. Slowed it down but not completely.
The other one is these 2 lines which I don't think is a big deal:
But, that line in the water pump, it just snaps in there and I didn't notice any way for it to seal up.
Thanks!
Thanks!
I could be mistaken, but I believe the inlet line into the water pump has an O ring on the end of it. It also has a clamp that bolts into the block to hold it in tightly. Did you put a new water pump on or was it the old one?
It's the old water pump. I didn't see an o-ring on the inlet line, so that would be the problem I'm assuming. First time I've ever had a dodge engine apart so I didn't know what was supposed to be there.
When you replace the inlet tube just make sure you use the bolt-down clamp as a guide for the farthest you shove it down into the water pump. Otherwise you may end up ruining the o-ring if it gets caught down in the pump. It's a super easy part to replace as you only need to loosen that bolt.
It may seem obvious but I made that mistake last week so I'm speaking from a recent learning experience. I shoved the tube too far down and when I pulled it back up to match the bracket the O-ring apparently got ruined...
Trending Topics
Your first picture> the water pump inlet tube, I've had to change a few times and its pretty simple. The oring that comes on it isnt sufficient and will start leaking soon. You can either buy a new tube from dodge or replace the oring. Either way, grease the oring and get some high temp RTV and apply a liberal amount ABOVE the Oring then install and tighten the fastener holding the tube. NOTE: your fix will last much longer and it will really help if you drained some coolant so the waterpump isnt full of coolant. or you can suck some out with a turkey baster or something...
Cheers
Cheers
Since no one discussed your second leak and I forgot to tell you in the last post.
Those lines typically leak from the clamped ends. I dont know if those pictured are oil lines or power steering lines and I cant go look at my truck now, but they're cheap and easy to replace. Now that I mention it, my power steering pressure hoses need to be replaced.
