Sorry, but Wild Vents Question
I have checked both check valves on the passenger side of the intake and both have vacuum and it only goes one way, so from reading the threads I believe them to be good. The problem is I only have defrost. I use to have air coming from the vents but when I took the CV off and reinstalled them all I'm getting is defrost. Did I screw up the vacuum somewhere or is this another separate issue? I don't have Cruise Control. Thanks for the help!
When you say you don't have cruise control do you mean it doesn't work, or the truck just doesn't have that option?
Smashed-And-Ram, certainly a possibility, that would cause your symptoms, that vacuum system runs the vents, 4x4 cad, and the cruise, so check all those lines. When I had that issue it was because of the cruise, the vacuum line running from the cruise was so brittle it had just completely broke, I replaced the brittle part of the line and then it was good to go.
Trending Topics
