one thing after another
Old Mar 23, 2011 | 12:13 AM
dvowicker's Avatar
dvowicker
Default one thing after another
okay so since i finally fixed my stuttering problem with my o2 sensor i have now gotten a new problem(s). first problem is when i get on my truck (hard) at high rpms i have a high pitched sqeak but only at high rpms. Second problem is it smells like burning brakes tonight i went for a ride and i smelt it so i got out of truck and checked all my fluids. everything was fine except for the coolant overflow which was pretty low. so i dont know where my coolant is going. and its not in my oil. i run royal purple and the oil was still purple so i know that its not going into my oil. third problem is the truck is acting like it doesnt want to stay in overdrive. i have a sct tuner and at about 45 it is running a high 2k rpm and wont shift into overdrive till about fifty but if im driving my truck running 60 and i let off the gas itll go down to about 55 and kick hard into drive... any suggestions on my newly aquired pains?
Old Mar 23, 2011 | 08:48 AM
BamaRam97's Avatar
BamaRam97
Could you possibly be loosing fluid around the water pump? The coolant could leak out and get on your belt causing the high pitch squeal and making a horrible burnt smell. You may want to check that.
Old Mar 23, 2011 | 09:54 AM
Doesn't the SCT tuner raise the shift points for fourth gear, and TCC engage?
Old Mar 24, 2011 | 12:18 PM
dvowicker's Avatar
dvowicker
Unhappy
Yes it does and I see no coolant coming out
Old Mar 24, 2011 | 12:22 PM
I think your upshift problem is "normal" for a truck with the tuner. For downshifting, might want to check TV cable adjustment.
Coolant leaks....... can be fun. I also have mystery coolant loss, but, no obvious signs of a leak, no puddle under the truck, no staining anywhere that I can see.... etc. it just.... vanishes.
How old is your serpentine belt? Any dirt in the groves? Pulleys? Any oil?
Old Mar 24, 2011 | 01:28 PM
dodgeboy1979's Avatar
dodgeboy1979
some small amounts of coolant will evaporate or vapourize from the resevoir, that is quite normal, especially if it is really hot out and you have had your truck working hard.
Old Mar 24, 2011 | 03:38 PM
Carl2206's Avatar
Carl2206
i shall x2 this statement......
Old Mar 24, 2011 | 04:50 PM
DodgeTheDadRamTheDaughter's Avatar
i had a crazy coolant loss problem before to where there were no visible leaks, then i notice a little bit of moisture randomly near the weep hole on the water pump, kind of hard to see with everything in the way and not a big a dripping of coolant either which is why i think i was losing coolant through my water pump but the heat was drying/causing it to evaporate before i noticed. After about a two years of this it finally turned more into a small drip but not so much that i would notice it on the ground. Then the pump just up and went the bearing was shot and it really started to leak.
Old Mar 24, 2011 | 05:11 PM
dvowicker's Avatar
dvowicker
Well.ill check my weep hole and see if I see anything but it only did that downshift thing that one time so im not sure about that and im thinking the smell is brakes because when I accelerate its pullin to the left bad and when I brake its pulling to the right. And it seems that that is where the smell is coming through at
Old Mar 24, 2011 | 06:27 PM
Seized caliper or stuck on the guides, or soft line gone bad.
