Help
Old Mar 24, 2011 | 02:53 PM
nelsont's Avatar
nelsont
Smile Help
My son's 99 ram 1/2 ton 4wd short box 318cu. engine has a issue when ever it is wet out that it will not start after sitting. Like something gets wet i/m guessing. After it sits for a day or to then it will fire right off.
Anyone have any ideas?
Tim
Old Mar 24, 2011 | 02:55 PM
Check the seal at the back of the hood, right above the intake manifold. It might be allowing water to drip onto the distributor......
If you ignition parts are old, that may also be an issue. (cap, rotor, wires, plugs.)
Old Mar 24, 2011 | 08:56 PM
ryan0714's Avatar
ryan0714
i second that, its gotta be the cover behind the hood lettin it in, maybe the rubber that run on the front edge of it is missing? and yes id call it the distributor gettin wet too, prob, will try to turn over, but wont fire off?
Old Mar 24, 2011 | 10:06 PM
dhvaughan's Avatar
dhvaughan
sometime when it won't crank - spray the hell out of the distributor cap from various angles with WD-40. if that doesn't work, spray the pcm connectors and wiring harness on the passenger side firewall.
