How can I make my tranny last longer?
Old Mar 25, 2011 | 10:28 PM
FireDodge's Avatar
FireDodge
Default How can I make my tranny last longer?
So I have my stock tranny still, and am not looking to get a new one until this one breaks, but I don't want it to, haha. So what can I do to help it? The previous owner said he had the tranny looked over by a certified tranny shop but didn't say what, if anything, they fixed.
I currently have 35's with 3.55's. I've heard some people say that new gears will help, and I've heard some say they won't.
Any advice will be appreciated! Thanks!
Old Mar 25, 2011 | 10:40 PM
atthewmartin114's Avatar
atthewmartin114
tranny flushes then called for in the book tranny filter and gasket services when called for. dont me shifting threw the gears well under high RPM. also dodge for some stupid reason made the trannys so they dont pump tranny fluid in park. so extended ideling causes the tranny to get hot and start to burn the fluid inside the tranny because its not being cooled by the fluid so just shut the truck off dont let it idle in park more then 10 minutes or so and you should be just fine. only other possibility is to change the tranny lines to one solid size line.
Old Mar 25, 2011 | 11:25 PM
Never Flush your trans. If it hasn't had it REGULARLY before, a flush is a bad plan. Just change the fluid and filter, and adjust the bands at the correct intervals.
If you don't have an auxiliary cooler, get one.
Delete the check valve in the cooler line running to the bottom of the radiator.
While you have the line apart, install a remote filter. (such as you see for engine oil)
Lower gears will indeed help your tranny live longer. It won't be working as hard to get those meats, and the heavy truck..... rolling. With 35's, 4.56 gears will keep rpm close to what is was with stock size tires. You will actually get better gas mileage too.......
Old Mar 25, 2011 | 11:32 PM
dhvaughan's Avatar
dhvaughan
do-
trans cooler, remote filter, remove check valve, drain plug, annual trans fluid changes (start with 2, 1-2 weeks apart), use ATF+4 only, replace governor pressure sensor and solenoid if you have a shifting problem. use superchips tune or updated pcm flash that moves OD shift out from 45 mph to about 53 mph.
don't-
neutral drops, tow with overdrive on, use any additives, adjust the bands unless you know what you're doing and have the right tools.
cooler pictures....
https://dodgeforum.com/forum/2nd-gen...ter-added.html
Old Mar 25, 2011 | 11:40 PM
JSTMoto's Avatar
JSTMoto
Gears WILL help prolong the life of your transmission. They simply make your truck easier to move. Expect lower gas milage, and higher RPMs. Also, they are pricey and if you have 4x4, you MUST do the front axle also. But, with 3.55s and 35s, you're not doing your trans any favors.
Keep your trans fluid cool. Get a quality aux cooler installed. A deep trans pan to hold more fluid is also a good idea.
Ditch the stock check ball in the stock cooling lines (write-ups available). This will require you to let your truck sit in neutral for a little bit before you take off in the mornings.
Use ONLY ATF +4 fluid.
DO NOT flush these transmissions!! A simple tranny pan drop and fill + filter change is what is recommended most.
Get the bands adjusted by someone who knows how to do it. In other words, not a shade tree mechanic.
atthewmartin bring up a good point as well. If sitting idle for a while, consider engaging the parking brake (if terrain allows) and putting the transmission in neutral.
And lastly, don't do dumb chit. This means: NO burnouts! NO neutral drops! NO red light racing!
-JT
Old Mar 25, 2011 | 11:47 PM
Actually, he will indeed get better mileage with lower gears. The engine won't have to work as hard to get the truck rolling, and it will be operating in its designed range when just cruising down the road. Not to mention there will be significantly less gear-hunting going on.......
Worst case scenario, he will get the same as he does now....... (provided his driving style stays the same.......)
Old Mar 26, 2011 | 01:50 AM
thetypezero's Avatar
thetypezero
+ 1 on the tranny cooler. Should be able to pick one up at any parts store If you don't want to hassle with ordering one online, And get a deeper tranny pan. Not sure if I'll get flamed for this. But I use B&M Trickshift ATF tranny fluid with this setup.
Old Mar 26, 2011 | 10:08 PM
dhvaughan's Avatar
dhvaughan
Old Mar 27, 2011 | 02:57 AM
JSTMoto's Avatar
JSTMoto
True, but I think it's best to always expect a mileage loss when lowering gears. So if you end up gaining a mpg or two, it'll help pay for a new blanket and pillow for the couch, because the lady is going to want to know why you just had to lay down a lump of bills to get 2 pairs of gears when the truck was working perfectly fine the way it was.
-JT
Old Mar 27, 2011 | 10:42 AM
-JT
LOLLOLOL
Ever the optimist?
Thanks for the giggle to start my day.
