tranny only works in 1st and second!!!!!!!!!
Old Mar 26, 2011 | 07:38 PM
dodgerambaby's Avatar
dodgerambaby
Default tranny only works in 1st and reverse
i have a 1995 dodge ram 4x4 automatic. i bought the truck and i drove it for an hour then all of a sudden it wont budge at the greenlight wont work in any gears. got it towed home and found out it doesnt have no tranny fluid haha. i put some in then all of a sudden it only is 1st gear and reverse. nothing else works. im gonna have to buy a tranny but is there anything i can check or add or anything, or any ideas anybody can think of... please i need help
Old Mar 26, 2011 | 08:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You can try changing the fluid and filter and adjust the bands.
Old Mar 26, 2011 | 11:13 PM
dhvaughan's Avatar
dhvaughan
you might still be low on fluid. check it with engine running, in NEUTRAL (for awhile), not in park. use atf+4 only. once full, let it idle in drive and reverse and recheck.
Old Mar 26, 2011 | 11:19 PM
cooper69's Avatar
cooper69
could be the sensors in the tranny.
Old Mar 27, 2011 | 01:27 AM
dodgerambaby
thank you i will try that but i poured it till it was full but i will try anything
Old Mar 27, 2011 | 04:42 AM
lukeca's Avatar
lukeca
Is it leaking maybe? Seems weird you would be able to get it to move at all for that hour before you found out it had no tranny fluid, cause it needs the pressure from the fluid to engage the gears.
Old Mar 27, 2011 | 08:48 AM
dodgerambaby
it was running good with out hesitation in the gears for that hour then bam nothing works
Old Mar 27, 2011 | 10:34 AM
Drop the pan, see what you find.
Old Mar 28, 2011 | 07:20 PM
dodgerambaby
DUDE IT WORKED MAN!!!!!!!!!!!! thank you bro
Old Mar 28, 2011 | 08:08 PM
What Worked?
