I'm going to shoot this truck ... 9mm NATO style!
Old Mar 28, 2011 | 11:45 PM
  #21
Smashed-And-RAM's Avatar
Smashed-And-RAM
Originally Posted by dsertdog56
I find it strange that parked truck not running would drop that much fluid out of a pump seal, but stranger things have happend.
I have also seen the stock steel pans rust out from road salt and drop a ton of fluid on the ground. It pretty much happens all at once. That was even stranger.
I would think. that if you refilled the tranny and started the truck and put it in neutral, engaging the pump, you would spew fluid like a mad man. That is if the pan is solid.
I think you'll find it quickly enough.
I don't even see it dripping when the pump is engaged. It's maddening. It can't be leaking that badly since it's not even losing any transmission fluid. I mean, if it is it has to minuscule since it's barely registering a loss on the dip stick. I just can't figure out why/how I had a 6"x6" pool on the driveway after it sat for a few days this weekend. It is for sure transmission fluid I got off the driveway ... good old sniff test, and it's pink fluid. So, it's not oil. (My first thought, actually.)
Old Mar 28, 2011 | 11:50 PM
  #22
Did you verify that it actually came from your truck? Was your trans low on fluid??
Old Mar 29, 2011 | 12:40 AM
  #23
Smashed-And-RAM
Yeah, it came from my truck. I looked at the bell housing and it's for sure got pink trans fluid on it. Fluid isn't low, and hasn't been since I bought the truck. It was about a quart low before I bought it, put 1 quart in it about 2 months ago and it's still just about right where I left it so I know the leak can't be that bad. I just don't like leaking trucks, especially with a brand new $15,000 driveway.
Old Mar 29, 2011 | 12:59 AM
  #24
CraZyNOTRT's Avatar
CraZyNOTRT
thats one filthy trans.
Old Mar 29, 2011 | 01:01 AM
  #25
TryMeImHard's Avatar
TryMeImHard
maybe you spent too much money on your driveway and not enough on your truck
Old Mar 29, 2011 | 01:10 AM
  #26
Truedge's Avatar
Truedge
Could it be the transfer case?
I say this because my transfer case leaks like a siev and I have a three by three oil spot under the truck as we speak
Old Mar 29, 2011 | 01:22 AM
  #27
Smashed-And-RAM
2wd, lol.
Old Mar 29, 2011 | 01:23 AM
  #28
Smashed-And-RAM
Yes, yes it is. Mostly slimy mud, but some of that is the recent leak.
Old Mar 29, 2011 | 01:26 AM
  #29
Smashed-And-RAM
If I had my way I would have put down gravel, but I live in the 'burbs and they've got laws around here. Six car driveway + garage, 6" thick on a pretty steep grade for the first 1/2 of the driveway = expensive job. I wanted asphalt or gravel, and the city just wouldn't allow it. Pretty sure they've got their hands in the concrete business.
Old Mar 29, 2011 | 02:24 AM
  #30
thetypezero's Avatar
thetypezero
Originally Posted by zman17
Sell it and get a Chevy .
Yeah I think your in the wrong forum!!!!
