Flexplate rattle?
Old Mar 31, 2011 | 01:46 PM
M Laborde's Avatar
M Laborde
Question Flexplate rattle?
Can anyone help me diagnose this noise? Broken flexplate or something worse?
http://www.youtube.com/watch?v=NKXyP29t5JU
Old Mar 31, 2011 | 01:53 PM
Does it get worse under load?
Old Mar 31, 2011 | 01:56 PM
M Laborde's Avatar
M Laborde
Good question. I can't hear it while driving but I've never had anyone put it in gear & rev it a little while I was underneath. Would that be considered enough load to check?
Old Mar 31, 2011 | 01:57 PM
Yep. Just be extremely careful. Don't wanna hear about members getting run over by their own trucks........
Old Mar 31, 2011 | 02:01 PM
M Laborde's Avatar
M Laborde
Yep. Probably wouldn't hear about it if it happened, though.
Old Mar 31, 2011 | 05:06 PM
UnregisteredUser's Avatar
UnregisteredUser
It could be a broken flex plate, could be a failed converter, could be a bolt backed out, and it could just be a pebble got in there, too. Pull the inspection cover and have a look. If the bolts are tight and there are no foreign objects in there, have a friend start the engine and rev it, transmission in Park, parking brake set, left foot firmly on the brake -- if the flex plate is cracked you'll get a lot more noise as it revs up, and see the converter move forward.
Usually, a broken flex plate makes enough noise that you'll hear it from inside the cab while driving, especially when accelerating.
Old Apr 2, 2011 | 11:50 AM
gipperkid's Avatar
gipperkid
COuld it be a bad pump in the transmission?
Old Apr 2, 2011 | 03:44 PM
Jimythefan's Avatar
Jimythefan
Is the starter drive gear releasing completely?
Old Dec 13, 2015 | 01:06 AM
Josh Emery's Avatar
Josh Emery
Default I have the same problem
I know this post is years old. Did anyone ever find the problem?
Old Dec 13, 2015 | 08:25 AM
There are so many different things that can cause interesting noises under your truck, that it is pretty much impossible to diagnose over the internet..... (posting a video helps.... but, no promises. )
Welcome to DF!
