Coolant Temp problem.
Old Apr 3, 2011 | 06:04 PM
aim4squirrels's Avatar
aim4squirrels
make sure you replace the one with only one wire. that goes to your gauge, the other 2 wire one is read by the PCM. or replace them both.
Old Apr 3, 2011 | 06:47 PM
Tradhunt's Avatar
Tradhunt
Will do. I will just replace both.
Old Apr 3, 2011 | 07:54 PM
Tradhunt's Avatar
Tradhunt
Well just stopped by Autozone since I was right by one while out. They only show a temp sensor and it has the 2 prong plug. I didn't see any other sensors from what I could see in the T-stat area.
Looking by the T-stat the sensor looks to have a 2 prong plug on it.
Old Apr 3, 2011 | 08:22 PM
aim4squirrels
The other one is on the other side.
Old Apr 3, 2011 | 08:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yea, the other one is under the alternator. (hard to see).
And please, add all the info about your truck to your sig.
Old Apr 3, 2011 | 11:21 PM
Tradhunt's Avatar
Tradhunt
Ok got ya. Well guess off to Napa auto parts tomorrow see if they have one.
Thanks
Old Apr 3, 2011 | 11:24 PM
Keep in mind, you have two..... you want the one to the passenger side of the thermostat housing. Should be a single wire connector. THAT is the one for the gauge.
Old Apr 8, 2011 | 10:48 AM
Tradhunt's Avatar
Tradhunt
Well got the temp sensor and temp sending unit replaced. Its a bit better but still running in the low 200's so thinking maybe a bad t-stat or the new radiator is not getting enough flow. I'll run by Napa and grab a new t-stat on the way home.
Old Apr 8, 2011 | 11:00 AM
crazzywolfie's Avatar
crazzywolfie
have you checked the coolant level? since you replaced a whole bunch of parts maybe there was some air in the system that has worked it's way into the rad.
Old Apr 14, 2011 | 07:21 PM
Tradhunt's Avatar
Tradhunt
The coolant hasn't changed much. I bleed out some air and let it run for a while. Got the sensors replaced and the gauge stayed around the 200 - 205 mark but when cold it doesn't seem like the Tstat opens up till around 220-230 then it will drop to about 200.
I talked to a mechanic that said check the temp of the radiator in and outlets. I got about 166-170 on the top and 144 on the bottom.
Just tested by the neck for the Tstat and got a reading of 209.
