Major Transmission killers...?
Old Apr 2, 2011 | 08:48 PM
tuski's Avatar
tuski
Default Major Transmission killers...?
So I know one of the biggest things that destroys a tranny is heat. But what are some other factors that contribute to dreaded transmission death?
Old Apr 2, 2011 | 08:57 PM
97Rampowerhouse's Avatar
97Rampowerhouse
Almost anything that is not normal driving
Old Apr 2, 2011 | 09:15 PM
PurplDodge's Avatar
PurplDodge
You want the #1 reason? Lack of maintenance.
Old Apr 2, 2011 | 09:16 PM
keepitrunning's Avatar
keepitrunning
Contaminated fluid.
Valve body relies on close tolerances, clutch pack seals are critical and dirt will destroy them. Oil is cheap! I change my fluid and filter every 25,000 K.
Old Apr 2, 2011 | 10:52 PM
Kwdog75's Avatar
Kwdog75
Running 35's with 3.55 gears towing your 30 foot travel trailer.
Old Apr 2, 2011 | 11:00 PM
crazzywolfie's Avatar
crazzywolfie
stupid check valve
Old Apr 2, 2011 | 11:04 PM
dhvaughan's Avatar
dhvaughan
towing in overdrive. od unit doesn't cool properly and overheats.
Old Apr 2, 2011 | 11:35 PM
Dodgeman000's Avatar
Dodgeman000
Not adjusting your bands
Old Apr 3, 2011 | 12:50 AM
Mad_Scientist's Avatar
Mad_Scientist
Having the chrysler emblem stamped into the housing.
Old Apr 3, 2011 | 07:46 AM
Moparman59's Avatar
Moparman59
Talking Lousy oil supply.
Driving around town in overdrive with a transmission not designed with enough oil flow to lubricate properly. One of the first things you do after ripping your screwed 518 tranny to pieces is drill another oil hole in the main shaft to ensure proper oiling. Thank-you Transgo Jr shift kit for this important modification information.
