Ok did that. Now it appears to be droping, but the power of the engine seem to be off some and the check engine light flashed. I havent seafomed it yet. Maybe a lil gunk n coolant from the plenum change?
CEL flashing is usually an engine miss. How do your plug wires look, and how are they routed? (there is a TSB in the faq section on plug wire routing).
Never touched the plug and wires during the plenum change. Will check them out after scanning the ecm. I think its a vacume leak somewhere.
After 2nd reinstall and still dealing with a vacume leak, i took it to a shop that gonna do it for 150. Man im beat. Should stress the importance of the gasket seals and clean surfaces. But all in all, i learned a few things.
