What is the OEM Champion plug on my 01?
Old 04-07-2011, 12:31 AM
vikingdiesel's Avatar
vikingdiesel
vikingdiesel is offline
are those 8 mm, though?
  #42
Old 04-07-2011, 12:47 AM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Dodge Forum Moderator
No, they are not 8mm.
But I have been running a 7mm set since I bought the truck 4 years ago, and not a single problem yet. Didn't even learn/perform the whole wire routing TSB until maybe two years ago, and thats just because this site makes me paranoid. I didn't notice any difference before or after the reroute. 8mm helps, but buying a quality set of wires helps just as much. The cheapos or worn out wires are what give you issues, from what I've seen.
  #43
Old 04-07-2011, 12:49 AM
vikingdiesel
give me an example of CHEAPOS and non-cheapos
  #44
Old 04-07-2011, 01:57 AM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
Autozone duracrap(cheapos)
MSD 8.5's (non cheapos). My gpa has a set of the bwd's on his ram and I've got a set of the bwd's on my 318 in my Mazda but it hasn't ran so I can't say if I like them but my Gpa likes his and he's picky.
  #45
Old 04-07-2011, 06:39 AM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
Cheapos: AutoZone Valucrap
Non-Cheapos: NAPA Belden 7.5mm, Magnecor, Mopar 7.5mm
  #46
Old 04-07-2011, 10:21 AM
vikingdiesel
seems like either 7mm or the bad boy 8.5mm:
https://www.napaonline.com/Catalog/C...RecType%3aA%29
Which which you guys rather do, the 7mm belden at Napa or the 7mm BWD at O'reilys with champion stock plugs?
  #47
Old 04-07-2011, 10:51 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
The Belden 7 mm,stock champion plugs (or champion truck plugs) and route the wires according to the TSB.
  #48
Old 04-07-2011, 11:01 AM
vikingdiesel
  #49
Old 04-07-2011, 11:04 AM
zman17's Avatar
zman17
zman17 is offline
Sure, as long as the cap has brass inserts, you are good to go.
  #50
Old 04-07-2011, 03:09 PM
PurplDodge's Avatar
PurplDodge
with the ECHLIN Dist. cap and rotor?
Yes, get that.
Quick Reply: What is the OEM Champion plug on my 01?
