A/C Blows Warm Air When Stopping Suddening
Old Apr 7, 2011 | 01:35 PM
  #21
MagnumVP's Avatar
MagnumVP
Just called the local Dodge dealership and they only have 1 CV (Part # 4549209) and it's $5.81. I'll pick it up while I'm out and replace the bad one (if I have one) when I have some time this weekend. I'll check the hoses prior to and see if I need to replace them as well.
Should I pick up a pcv valve while I'm there?
Old Apr 7, 2011 | 05:44 PM
  #22
Mad_Scientist's Avatar
Mad_Scientist
Cant hurt, as they fail somewhat frequently, but a bad pcv does not constitute a vac leak (at least I dont think it would)
Old Apr 7, 2011 | 08:36 PM
  #23
MagnumVP's Avatar
MagnumVP
It's FIXED!!!! Finger's crossed that when I take it out tomorrow it's fixed as well.
I went down the the dealership and picked up the last CV. While I was there I picked up a pcv value as well. Total price $15.18.
I went home I first looked at the lines under the battery that goes to the Cruise Control. They looked fine. Then I decided to just take a look and see what it would take to replace the CV and pcv. It's nothing. Just a slight tug and twist and it was out. I found one CV just under the air filter on the passenger side. I took it out and blew in one way and then couldn't blow through it the other way. So I thought that one was good and put it back in place.
I looked for the other CV but couldn't find it so I decided to pull the pcv and replace that. With the NEW pcv I could both both directions. One direction is harder but I was still able to pass air. I pulled out the old pcv and tested that. I could NOT blow in one direction. I'm not sure if that matters.
After only replacing the pcv I now have Cruise Control, 4WD and I can NOT trigger the A/C turning to Heater "Weird Vents" thing again.
I would say that it's fixed, but tomorrow is the true test when I'll be out and about all day instead of just a quick 5 minute test drive to the corner and back.
THANK YOU FOR EVERYONE THAT HELPED!!!! I LOVE THIS PLACE!!!!
