01 Transmission Broke??
Old Apr 12, 2011 | 09:18 PM
Dirty01Sport's Avatar
Dirty01Sport
Default 01 Transmission Broke?? Pulled Pan PICS Inside
I know this has been covered million times and I searched around and came up with a couple possibilities....
What happened.....I have had no problems before this it just happened out of no where. I was getting on the highway on ramp at normal speeds. All of sudden the rpms jump up and the truck will no longer go forward. Now when in gear it will catch sometimes and move alittle then stop and rev up again. This happens in all gears R-D-2-1. It wont even engage in 4wd. Now when in gear you can hear what seems to be clunking noise like something is turning? Even in neutral you can hear it. Had my buddy check the fluid and its not going down when in neutral like it should. So could this be a broken flexplate , filter clogged, tranny pump?
Its a 2001 5.2 with offroad package with 90,000. Everything is stock.
Sorry for the long post but any input is welcome.
Old Apr 12, 2011 | 10:15 PM
97tn4x4's Avatar
97tn4x4
Sounds like rebuild time to me.
Old Apr 12, 2011 | 10:27 PM
95RAM360's Avatar
95RAM360
yep...
Old Apr 12, 2011 | 11:57 PM
Mad_Scientist's Avatar
Mad_Scientist
Torque converter may have **** the sheets
First order of business: drop the pan and see what you find... most likely rebuild time though
Old Apr 13, 2011 | 03:07 PM
Dirty01Sport
Pulled the pan and found some things.....magnet was full of metal and found what looks like part of snap ring that was stuck to the magnet
Ideas?
Old Apr 13, 2011 | 03:59 PM
Mad_Scientist
Hate to say it man, but it's definitely rebuild time
Old Apr 13, 2011 | 06:28 PM
Snap ring is a retainer for some parts in the O/D unit...... It looks like rebuild time......
Old Apr 13, 2011 | 07:57 PM
Dirty01Sport
Yea I was thinking the same thing....Im going to look around and see if I cant find a used one to drop in first then go from there
