Engine Missfire; Barely on the gas!
Old Apr 17, 2011 | 11:06 AM
ChaseMerola's Avatar
ChaseMerola
Ok just went outside and started it up, and started driving immediately, up untill the engine warmed up. It skipped hot or cold everywhere but idle or flooring it.
Old Apr 17, 2011 | 11:11 AM
ChaseMerola
How's your coil? Do you get a nice fat blue spark at the plugs?
Missed you post till just now, sorry about that. I get a nice long blue spark off all my sparkplug wires. Some guy from autozone told me a coil either works or it doesnt, so i havn't put to much thought into that. Is that statement true?
Old Apr 17, 2011 | 11:17 AM
I don't think the coil is your problem then. Gotta be something else messin' with ya.
Old Apr 17, 2011 | 11:36 AM
ChaseMerola
What do you think about the o2 thing, HeyYou?
Old Apr 17, 2011 | 11:52 AM
Usual signs of a failing O2 sensor is it starts running funny after running for about two to three minutes. (when the O2 sensor heats up, and the PCM actually starts paying attention to it.) If your problem manifests immediately, it probably isn't the O2. If it's pretty old though, sure wouldn't hurt to replace it.
Old Apr 17, 2011 | 01:39 PM
ChaseMerola
Lightbulb
Alright, I am heading home in a couple of hours, to test....
ToDo:
- Check Sparkplugs for Improper Fouling
- Take Fuel Rail & Injectors off to clean
- Check Plenum
- Run OBD-I Diagnostic test
- Test Fuel Pressure agian
- Replace vacuum lines.
- (Possibly replace o2 if nothing else works.)
Will report back this evening with my findings.
Old Apr 17, 2011 | 02:05 PM
atthewmartin114's Avatar
atthewmartin114
if its skipping right out of the box i wouldnt be changing o2 sensors because that a waste of a few hundrad bucks. i would be checking fuel pressure. timing and firing order. intake to see if its burning oil or not. and if its the same little skip i hard i would be changing the cam gear and doign an intake set because the teeth on my cam gear where shot. also the fuel filter and pressure regulator can cause this. a delay in any one will make a skip.
and got the coil thing. no the autozone guy was wrong. i have two coils that work great until the truck is warm or until your under WOT for a few seconds and the coil heats up then it dies. and normally coil brake downs will cause a skip. the chevy V6 cars are known for it. the gen 2 3400 and 3800 have split packs and they brake down the same way causing a skip.
Old Apr 17, 2011 | 10:43 PM
aim4squirrels's Avatar
aim4squirrels
Engine too cold to long is usually the sign of too cold a thermostat installed, or a thermostat that has failed in the open position. Usually it causes you to run rich.
Old Apr 17, 2011 | 11:29 PM
ChaseMerola
Update: Checked off that list of ToDo's, Everything is clean as a whistle.
Was on the way home, stopped by autozone and grabbed a MAP and Fuel Position sensor just to rule them out. Turns out the map NOR the FPS was the culprit. SO... its not them.
Old Apr 18, 2011 | 11:47 PM
WhiteBoy BlackDodge's Avatar
WhiteBoy BlackDodge
Default got same problem
got a 99 1500 4x4 with 5.2 been doing same for a month or so. changed throttle position sensor, cleaned idle air control ( which really needed it), plugs, wires, dist, rotor, etc., checked vac lines, o2 sensors show ok with ohmmeter, checked batt voltage & cleaned posts............still same little miss when takin off. especially uphill. wonderin bout fuel pressure too. it acts like i need to change fuel filter if it was on a ride where i could. good luck, ill let u know, u let me
