Dodge 9.25 options..
Old Apr 17, 2011 | 12:18 PM
Kwdog75's Avatar
Kwdog75
Default Dodge 9.25 options..
What are you guys running for a posi or locker?
Been looking at a few different setups but most seem to be way out of my price range. I've been looking at these three...
-Yukon Dura-grip
-Spicer Trac-loc
-Lock-Right
Which one would you choose?
Old Apr 17, 2011 | 01:56 PM
grox's Avatar
grox
Well, I don't think that Yukon makes one for the 9.25". So I would stay away from that.
The Lock-Right should do better than the Trac-loc.
Old Apr 17, 2011 | 02:05 PM
Kwdog75's Avatar
Kwdog75
Ever try an Auburn gear posi?
Old Apr 17, 2011 | 02:11 PM
94Beater's Avatar
94Beater
This is what I got
http://www.xtremeterrain.com/chrysle...liplocker.aspx
You can find them for less, but the installation is relatively simple.
I only got about 1000 miles on it so far. But so far so good.
Old Apr 17, 2011 | 02:17 PM
Kwdog75's Avatar
Kwdog75
I'd like to get one of those but the bigger question is can i remove the posi in the rear end i have now and install one of those?
Old Apr 17, 2011 | 02:19 PM
Kwdog75's Avatar
Kwdog75
I keep seeing the Yukon Dura-grip for the 9.25 on Ebay but i wonder if they are full of manure.
Old Apr 17, 2011 | 02:24 PM
94Beater's Avatar
94Beater
I had an open carrier when I installed mine.
I'm not sure if it will fit carrier with posi. You can try to contact manufacturer and see if they have this specified somewhere.
Your other option is to get an open carrier (from junkyard) and use it to install Powertrax.
But you'll have to set up your backlash again.
Old Apr 17, 2011 | 02:33 PM
Kwdog75's Avatar
Kwdog75
If i get a used open carrier from the scrap yard and get the Powertrax, it will cost me just as much as getting a Truetrac.
At that point maybe i should look at an Auburn LSD?
Do you think the Powertax is worth the extra money or should i just buy a Truetrac? Keep in mind i will be going to a 4.56 or 4.88 gear when all is said and done.
Old Apr 17, 2011 | 02:48 PM
Silver_Dodge's Avatar
Silver_Dodge
I have an Auburn limited slip and have been very happy with it. How do you use your truck? Do you need a full locker, or just a posi/limited slip? For full locker, Detroit/Eaton is the only way to go IMO.
Old Apr 17, 2011 | 02:49 PM
Kwdog75's Avatar
Kwdog75
during 9 months out of the year it doesn't matter but for hunting seaon and when i put the boat in the water i need some serious traction.
I will be using a mini spool in the front, Maybe i can get away with using an Auburn in the rear?
