won't start
Old Apr 19, 2011 | 06:33 PM
DirtRider1357's Avatar
DirtRider1357
Default won't start
97 ram 1500, extended cab, 4x4, 5speed, 5.2l, new plugs wires cap and rotor, plenum fixed.
When i get gas my truck wont start after im done pumping the gas. it turns over and wont start. if you pump the gas while starting it, it will eventually start but it will run really rough for like 15 seconds. then while driving, when you push the clutch in and start slowing down, the rpms drop down to 50 or it just stalls. if it stall, then it wont start right away just like after i get gas. also, its not throwing any codes.
Any ideas?
Old Apr 19, 2011 | 08:28 PM
redneck_ram's Avatar
redneck_ram
sounds like the coil isnt sending enough volts to the plugs.... id say check the resistance on the coil and go from there! also check your tps and iac, that could help your idle issues.
Old Apr 19, 2011 | 08:34 PM
97tn4x4's Avatar
97tn4x4
How's your battery? I know they won't idle right and you saying after it sits getting gas it's harder to start. Might be worth looking into.
Old Apr 19, 2011 | 08:44 PM
97tn4x4's Avatar
97tn4x4
Old Apr 24, 2011 | 05:50 AM
DirtRider1357
my cel just came on and its for the engine coolant temperature sensor
Old Apr 24, 2011 | 08:34 AM
On yours, that will be the one on the drivers side of the thermostat housing. (you have two.) Check the connector first, make sure it is clean and tight. If you can, plug a scanner into it, and see what the PCM thinks engine temp is, vs. what it really is. If there is a discrepancy there, replace the sensor.
