engine cutting out???
Old 04-20-2011 | 05:42 PM
95BIGRED's Avatar
95BIGRED
Default engine cutting out???
going down the freeway if i have to kick the od off my engine will cutout for about a second and then it goes back to the same rpm as before. usually happens over 3000 rpms but sometimes lower. dont know wtf.
Old 04-20-2011 | 08:24 PM
That seems odd. It isn't bouncing off the rev limiter is it?
Old 04-20-2011 | 09:38 PM
Ramzy's Avatar
Ramzy
Are you seeing an RPM drop on the tach or is the feeling more of a long delay in the shift?
Old 04-21-2011 | 06:10 PM
95BIGRED's Avatar
95BIGRED
like i said going down the freeway if i kick the od off ill be around 3000rpms and all of the sudden it will just cut out you can hear it feel it and see it on the tach. i have no idea why its doing it. if im getting on it it usually wont happen until im closer to 4000rpms but no its not bouncing off the rev limiter im not even coming close to redlining it.
95BIGRED's Avatar
95BIGRED
not even a second after it cuts out the power returns
Old 04-22-2011 | 12:14 PM
95BIGRED's Avatar
95BIGRED
anyone??............?.?.?.?
Old 04-22-2011 | 03:55 PM
An odd one..... just as a wild guess, try swapping the ASD relay, with another, like, the wiper relay..... see if that makes any difference.
Being able to data log here would be very nice, but, I know very few people actually have that capability...
Old 04-22-2011 | 06:01 PM
95BIGRED's Avatar
95BIGRED
well today i noticed a whole new symptom, on the freway again doing about 75 i floor it and it did nothing for about 10 seconds and then it down shifted and bogged down, it was about 5 seconds before i could resume normal driving. while bogging down it jumped and lurched a few times. as far as i can tell it is only doing this in 3rd gear.
Old 04-22-2011 | 06:44 PM
another 'only in third gear' problem?????
Check your fuel pressure...... would be nice if you could place the gauge so you could see it while driving, and see what it does when you step down hard on the gas.
Old 04-22-2011 | 06:59 PM
Ramzy's Avatar
Ramzy
Sure sounds like momentary fuel starvation. I second HeyYou, I wonder what the fuel pressure is doing while all of this is happening.
Quick Reply: engine cutting out???
