AC CLUTCH ??? tried most things i think >
Old Apr 22, 2011 | 11:23 PM
velocity37's Avatar
velocity37
Default AC CLUTCH ??? tried most things i think >
So my 99 5.9L is having some ac problems I am assuming it is the clutch but Ill let you guys chime in before I drop the $300 bucks. So heres what ive tried.
1. Jumped the high pressure side connecter and nothing
2. Jumped the low pressure connector all that happens in the idle increases a little bit
3. swapped the fuel pump and ac relays , no change
5. checked as many ac connections as i could find for voltage and all i checked checked out ok.
Any other suggestions or help guys would be great
Old Apr 23, 2011 | 07:32 AM
Novarider's Avatar
Novarider
If you couldn't get the compressor to turn over by jumping the switch then it's probably bad. Most places require you to replace a couple parts (dryer, orifice tube, evaporator) with the compressor for them to honor the warranty on the compressor so check with whoever your getting it from.
I have bought a junk yard compressor before that was only $30 and it works fine. Might be a way to save some money
Old Apr 23, 2011 | 09:01 AM
Do you get voltage at the connector for the A/C clutch?
