ABS and emergency brake lights turned on?
Old Apr 28, 2011 | 12:50 AM
99dodge318's Avatar
99dodge318
also have you tried to release the parking brake? my brake light will stay on if i dont pull the release two or three times.
Old Apr 28, 2011 | 03:18 PM
joeyd208's Avatar
joeyd208
yeah i tried that, i pushed it down released it and wiggled it around just in case that was the problem but nothing.... oh well ill pop that part out and replace it no biggie and hopefully that takes care of those annoying little lights lol!
Old Apr 28, 2011 | 06:08 PM
seabass202's Avatar
seabass202
I had this problem as well, after replacing everything it ended up being the abs module/computer in the dash I think it was somewhere behind the climate control maybe a little lower toward the middle. got one from the local pick and pull for a couple bucks.
Old May 7, 2011 | 06:08 PM
Murphy 1112's Avatar
Murphy 1112
I just had this problem crop up this week. The light came on after hauling about 800 lbs worth of cement and now wont come off.
On a 2001 ext cab 4x4 is this sensor still on the rear diff? I'll be crawling under tomorrow to have a look around.
Old May 7, 2011 | 06:21 PM
muzz3256's Avatar
muzz3256
Weird, I had this problem on Thursday after I flashed my truck with my new SCT, I reverted back to stock and it stayed that way, so I flashed back to the 87 tune and they were still lit. I was beginning to get a little pi**ed off, so I took the truck for a drive, and they both went off after about 20 feet. Haven't seen the problem return, and I'm hoping that it stays that way.
Old May 20, 2011 | 06:05 PM
gobucs963's Avatar
gobucs963
Default abs and brake light
Hi all newbie here, I am having the same problems. pulling trailer or heavy stop and go traffic. abs and brake light comes on, every now and then i feel feed back in the brake pedal. replaced front wheel hubs about a year ago. luv my 04 hemi, could you give me a direction to go in here.
Old Jun 29, 2011 | 07:11 AM
8uzzsaw's Avatar
8uzzsaw
I just encountered this problem with my '98 Ram and it includes my spedometer fluttering or even just sitting at 0 while im doing under 50 km/h. Is it the same fix or should I be looking at something different?
Old Jun 29, 2011 | 09:26 AM
Post on the third gen boards.
If you only have RWAL, check the connector on the rear wheel speed sensor, make sure it is clean, and tight. If that doesn't help, replace the sensor.
Old Oct 6, 2011 | 06:36 AM
joekool4's Avatar
joekool4
Same problem just came up on my 98 1500. About a 10 days ago i hauled a ton (literally 1920lbs) of dirt grass and mud to the landfill, then went on a 600 mile round trip last weekend. didnt drive it for two days then took it for a drive and the ABS and ebrake light stayed on. the entire 600 mile trip nothing then when i got back it was on. I've notice that if I put in neutral and shut it off while going, then turn it back on it will go out until I shut it off again.
Old Oct 6, 2011 | 07:33 AM
8uzzsaw's Avatar
8uzzsaw
My connection ended up being a little dirty. My wiring harness for it looks like its seen better days though, and with the off-roading I do I will be replacing that soon. Anyone know how much that runs? I found a few online but no price was listed.
EDIT: Part #DOR1673379. Is this the correct one for my truck?
