Fuel Sync off .. Possibly ???
Old Apr 26, 2011 | 01:06 PM
Cwarden07's Avatar
Cwarden07
Default Fuel Sync off .. Possibly ???
I need to know what are the symptoms of the fuel sync being way outta wack ? Any ideas will be greatly appreciated !
Old Apr 26, 2011 | 01:35 PM
J415's Avatar
J415
Better yet, what symptoms are you having?
Old Apr 26, 2011 | 02:23 PM
Cwarden07's Avatar
Cwarden07
When i go to accelerate it pops and cuts out and juss wont go and is very very sluggish and sometimes backfires. Im doing the sync and getting a new map sensor cause im getting a cel stating bank 1 is too lean
Old Apr 26, 2011 | 02:30 PM
might be a bad O2 sensor, or failed cat, blown plenum, etc.
Old Apr 26, 2011 | 02:37 PM
Cwarden07's Avatar
Cwarden07
I cut the cat off and the 02 sensors are unplugged ... How do I know if the plenum is bad ? and i was also told maybe the MAP sensor was bad
Old Apr 26, 2011 | 03:16 PM
Check the End all... plenum thread. Its stickied.
MAP sensors rarely fail.
Old Apr 27, 2011 | 06:14 PM
Cwarden07's Avatar
Cwarden07
Well got the truck back from the dealer .. runs alot better but it still will surge out and pop sometimes.... i dont have the cat all the way on and the spark plug wires are melted but they are off the header. There is black soot all over my spark plugs and end of tailpipe. Im thinking a full mopar performace tune up with new o2 sensors and new cat will do the trick !! What do yall think ?
Old Apr 27, 2011 | 06:24 PM
Verify your plenum isn't blown, or you will get to do it all again.
Old Apr 27, 2011 | 09:33 PM
aim4squirrels's Avatar
aim4squirrels
Did you say your o2 sensors are unplugged? Plug them back in.
Old Apr 27, 2011 | 09:40 PM
aim4squirrels
If wires are melted but you are sure the headers did not cause it, you gave some serious resistance issues or maybe an over volt problem. Check the coil. And look for induction crossfire (blue sparks traveling between the wires at night). Also make 100% sure the wire routing is correct from the cap to the correct spark plug.
