manual conversion
Old Apr 26, 2011 | 11:50 PM
FROZNTXN's Avatar
FROZNTXN
Default manual conversion
ok so i did a auto to manual conversion on my 96 dodge ram 1500 with a 360 i replaced my 46 RE with a 86 NP435 granny 4 speed, everything works like a dream, but my check engine light is now on im assuming its because the CPU isnt reading the computer anymore so im wondering if there is a quick wireing bypass to fool the computer into thinking its there. anyone have any thoughts
Old Apr 27, 2011 | 12:02 AM
99dodge318's Avatar
99dodge318
you have to find a 96 manual cpu and since they never made 1/2 ton 5.9 standard you have to find a cpu out of a 3/4 ton
Old Apr 27, 2011 | 12:40 AM
jasonw's Avatar
jasonw
Site Moderator
And then get it flashed at a $tealership with your correct VIN, mileage, etc.
Old Apr 27, 2011 | 12:41 PM
RamNJeep's Avatar
RamNJeep
I've been thinking of the same conversion with a NV4500. what did you end up doing with the automatic column and the P-R-N-D stuff?
Old Apr 27, 2011 | 12:58 PM
whatman27's Avatar
whatman27
I did a tranny swap on my truck I have a 94 1500 with a 318 an I put in a nv3500 I nvr flashed my pcm an it runs fine.. Should I flash it though ?
Old Apr 28, 2011 | 12:51 PM
FROZNTXN's Avatar
FROZNTXN
RamNjeep I just left the column alone removed the auto shift lever and the prnd12 left alone doesn't bother me
Old Apr 28, 2011 | 12:56 PM
99dodge318's Avatar
99dodge318
frozen you put a trans out of a 1986 dodge into your 1996?
wow your gas milage must be at like 8 mpgs! lol especially a 4 speed with granny first, but i bet you could yake a tree out of the ground with no problem
Old Apr 28, 2011 | 04:39 PM
Gerehead8's Avatar
Gerehead8
You don't need to. The 1994 auto (46RH) has an actual governor not a governor solenoid and all the other electronics. The only things that are electronic on your tranny are the park/neutral sensor (should now be the clutch sensor) and the OD and lock up solenoid. You might get a code but it should not effect anything.
Old Apr 28, 2011 | 04:42 PM
Gerehead8's Avatar
Gerehead8
Its going to be better than yours if you ran around with OD off (both trannies would be 1:1 and no torque converter slip or power loss to a pump in a manual). It would make a great tranny for a beater or something that tows all day.
