Leveling/Lift Kit...need advice
Old Apr 27, 2011 | 01:18 AM
BMXandSLED's Avatar
BMXandSLED
Default Leveling/Lift Kit...need advice
Hey guys so im pickin up my 98 ram 1500 4x4. I got three choices to do so and i want some advice on the cheapest and easiest way. My first choice is a 2.5 inch leveling kit by rough country($100). Second is a 3 inch suspension lift by rough country($499+labour). Or i found a leveling lift kit made by a company called suspensionmaxx...its got a 3 inch front leveling kit and a 2 inch rear block kit($290). Im thinking about the last choice, it seems like a solid product and only reason im doing all this in first place is because my tires rub, should pick it up just the perfect amount. Also if i decide to go with one of the leveling kits is it necessary to get a sway bar link kit as well or can you get away without one? Thanks.
Old Apr 27, 2011 | 04:06 AM
97tn4x4's Avatar
97tn4x4
http://www.topguncustomz.com/Store/G...iview=25473996
Here's a much better price. No you don't don't need sway bar end links. You don't need anything extra for a 3" lift. If you have a basic set of tools, a jack and jack stands you could easily do this in a day with a friends help.
Old Apr 27, 2011 | 12:08 PM
BMXandSLED's Avatar
BMXandSLED
hey thanks man appreciate it, you just saved me alot of screwin around and some money ha. Should be good, my biggest concern was that i live in canada and i do put weight in my truck in the winter but i think with this kit it should still have enough rake so it wont sack the rear end.
Old Apr 27, 2011 | 06:23 PM
ryan0714's Avatar
ryan0714
yea im leanin for that kit too, but i am just so damn iffy about stackin blocks and going offroad and them gettin shifted.
Old Apr 27, 2011 | 07:06 PM
97tn4x4's Avatar
97tn4x4
You can buy just the front spacers and shocks as a kit then buy a 2" aal which will also help with payload.
http://www.topguncustomz.com/Store/G...view=161984906
Also hellbentsteel.com makes a 2.5" spacer
http://www.hellbentsteel.com/product...eling-kit.html
Old Apr 27, 2011 | 08:50 PM
BMXandSLED's Avatar
BMXandSLED
Are new shocks necessary? If they are I think i be more comfortable with spendin extra money on this...
http://www.topguncustomz.com/Store/G...iview=25474006
...and just replace the blocks with 2" aal for $30 extra. Or else ill just get the 2.5" spacer for front and 2" aal for back and keep stock shocks, wouldnt be more than $200 then. Is the kit i mentioned first worth the extra couple hundred for the 4 shocks and 3" spacers?
Old Apr 27, 2011 | 09:26 PM
BMXandSLED's Avatar
BMXandSLED
sorry nvm i got confused on the shocks. But i think im going with the kit i mentioned above and just get the aal instead of blocks. Thanks guys!
Old Apr 27, 2011 | 10:12 PM
shorty24v's Avatar
shorty24v
I got the lift mentioned in the first response. I also got new rear shocks because I needed new ones. For pics click on the link in my signature. Thats with the truck on 285/75 16 almost 33" tires.
Old Apr 27, 2011 | 11:28 PM
97tn4x4's Avatar
97tn4x4
New shocks aren't required but if you need them might as well get them
Old Apr 28, 2011 | 01:10 AM
99dodge318's Avatar
99dodge318
yeah do it right the first time so you dont have to worry for a while
i didnt install new shocks cause i was cheap at the time, come to find out while installing the spacer, i had to extend the driver side shock by hand cause it was already blown.
now 5 months later i have to tear into the front suspension AGAIN to replace both front shocks.
but this time i have some extra cash so im also gonna get a dual shock mount for the front along with 4 extend length shocks
http://www.topguncustomz.com/Store/G...view=190138296
http://www.topguncustomz.com/Store/G...view=186459476
what do yall think?
