Cam and crank ailgnment
Old Apr 28, 2011 | 09:31 PM
slantedcuda's Avatar
slantedcuda
Default Cam and crank ailgnment
I have a 98 dodge 5.9 / 360. timing chain cover gasket blew a antifreeze leak. Had no problems getting everything off but i decided to change the timing chain since it had some slack and 182,000 miles on it. I removed the chain and put the new one on not disturbing the cam or crank. Reinstalled everything and tried to start with no luck thought i messed up got back into it and checked the ailgnment and it seems every thing is good but still no start. Is there a way to guarntee the cam is in the right position I know the motor shoud be tdc on number 1 or is there something else i screwed up? Wishin I never touched the timing chain it ran good until this
Old Apr 28, 2011 | 09:47 PM
aim4squirrels's Avatar
aim4squirrels
the cam and crank sprocket should both have a marking on them, like a dot or notch.
When the engine is at#1 tdc, both markings should be at 12 o'clock.
Also just be sure you plugged everything back in, there's a crap loss of stuff you have to move to get that timing cover off.
Old Apr 28, 2011 | 11:09 PM
slantedcuda
cam is at 6 o'clock crank at 12
Old Apr 29, 2011 | 08:54 AM
Need to find out what's missing. Do you hear the fuel pump prime? Are you getting spark?
Old May 3, 2011 | 07:19 PM
Rockyhigh360's Avatar
Rockyhigh360
Did you remove the distributor shaft? It could be 180 off
Old May 3, 2011 | 07:28 PM
tweeker909's Avatar
tweeker909
If thats with #1TDC then your crank needs to be turned 360 to bring the #6TDC. From factory dot to dot is based off the #6 slug not #1....Dot to Dot puts the rotor pointing to the #6 terminal......
Old May 4, 2011 | 11:50 AM
RamNJeep's Avatar
RamNJeep
Check your lifters, youre probably on #1 TDC, just on the EXHAUST stroke. You should be on the COMPRESSION stroke. That would put your dots to 12 oclock
Old May 4, 2011 | 12:15 PM
charlie1935's Avatar
charlie1935
The gears go on one way.
The dots or marks should be together (Mark on cam gear down, mark on crank gear up).
Number 6 will be in firing position.
Old May 4, 2011 | 12:20 PM
RamNJeep's Avatar
RamNJeep
why would you base your timing on #6? Its always been #1 TDC, thats why the distributor has "NO. 1 CYL." marked on the black plastic dust shield. Otherwise, you're aiming the rotor backwards?
Old May 4, 2011 | 06:03 PM
aim4squirrels
#1 tdc of compression stroke is not dot to dot on the magnum engine. Its both dots at 12 o'clock. Dot to for would be tdc at #6 compression stroke. Use #1 tdc if you font have a degree wheel so you can use the rotor button and harmonic damper marks to help.
