sway bar hitting diff
Old Apr 28, 2011 | 11:00 PM
offroadjosh's Avatar
offroadjosh
Default sway bar hitting diff
Noticed the other day when driving the cummins that the front sway bar is hitting the differential cover when turning really sharp.. Any ideas what could cause this? All the front end parts have less than 10k on them. (and its hit hard enough to wear in to the diff cover)
Old Apr 28, 2011 | 11:07 PM
offroadjosh
make that track bar....
Old Apr 29, 2011 | 01:27 AM
99dodge318's Avatar
99dodge318
maybe you tie rod? the tie rod runs across your axle in front of the diff, trac bar goes from passenger side axle to driver side frame, sway bar run above the axle and attaches at each knuckle.
you could just post a pic so we dont have to guess what one another are talking about.
is it only at full lock? if so i would extend the knuckle stops on each side of the axle to prevent it from turning too far and causing your problem.
if you mash the diff cover too much it will start to contact your axles internals, and thats bad news no matter how you look at it.
Old Apr 29, 2011 | 08:35 AM
Pics Please?
Old Apr 29, 2011 | 12:24 PM
offroadjosh
yup ill post a pic shortly!
Old Apr 30, 2011 | 01:32 PM
BlueBeast2's Avatar
BlueBeast2
is it lifted? Just a thought here cause if it is lifted and the track bar is stock it could cause issues I believe. That's why there is aftermarket ones made for lifted trucks :shrug:
Old Apr 30, 2011 | 07:47 PM
offroadjosh
Found the issue! Its an aftermarket track bar thats larger than stock... Going to be going to a 3rd gen track bar now :P
Old Apr 30, 2011 | 08:44 PM
mavrick651's Avatar
mavrick651
My ram was doing the same thing and as it turned out it was the sway bar links needed to be replaced.
