94 wont start
Old 05-02-2011, 12:07 PM
jason4321's Avatar
jason4321
jason4321 is offline
Default 94 wont start
Hey everyone I have a 94 RAM with a 5.9.
I can't get it to start. I have spark and plenty of fuel pressure. Tune up was just done not to long ago. It sounds like it wants to start sometimes but won't. Any ideas?
Old 05-02-2011, 12:11 PM
drewactual's Avatar
drewactual
drewactual is offline
gonna need to give us more than that!!!
sounds like it wants to? meaning coughing?
do you have the firing order right? Is there a chance you twisted the dizzy ANY while replacing the cap?
Old 05-02-2011, 12:22 PM
jason4321's Avatar
jason4321
Firing order is right and yeah its coughing. Could it be the pick up coil?
Old 05-02-2011, 01:03 PM
drewactual's Avatar
drewactual
you said you were getting spark, right? Could be, but it's been my experience with a pick-up coil that it misfires at cruising RPM's when it's about to go..
I'm questioning your fuel sync.. and that is the reason I asked if you spun the dizzy any.. I'd look toward CPS as well..
first things first though- verify fuel, verify fire, verify air.
Old 05-02-2011, 01:05 PM
jason4321's Avatar
jason4321
What is this dizzy you're talking about? if you mean the distributor it hasn't been moved at all. And yes I have a strong spark and all injectors are firing and there is air
Old 05-02-2011, 01:14 PM
drewactual's Avatar
drewactual
dizzy is your distributor.
cool- you're likely looking at a bad CPS then most likely.. I'm assuming a lot, but I'm guessing you did a tune for a reason, and now you're having issues after a bit..
The CPS is responsible for knowing where your crank/pistons are at in terms of your ignition timing.. It sounds like your timing may be out of whack.. Get a new sensor from the dealer as opposed to aftermarket place and swap it out.. see what happens..
TRY this though- disconnect your battery for a few minutes- then reconnect it and try to start..
Old 05-02-2011, 01:18 PM
jason4321's Avatar
jason4321
Where is the crank sensor located? And if the crank sensor is bad should I not be getting spark and fuel?
Old 05-02-2011, 02:37 PM
Mad_Scientist's Avatar
Mad_Scientist
Mad_Scientist is offline
CPS is cam sensor, CKPS is crank...
To answer your question, the cam sensor is in the distributor...
Old 05-02-2011, 03:38 PM
jason4321's Avatar
jason4321
Arrow
The cps is the pickup coil?
Old 05-02-2011, 03:45 PM
drewactual's Avatar
drewactual
I stand corrected.. it may be CKPS.. so, get a new CKPS.
you can use the search feature to find out how.
Quick Reply: 94 wont start
