Rear Main Seal
Old May 3, 2011 | 03:29 PM
EHS22's Avatar
EHS22
Default Rear Main Seal
How much do you think it would cost to rebuild the rear main seal on my 5.2 V8. Better yet, how much do you think it would be for a full engine rebuild?
Old May 3, 2011 | 03:38 PM
matty675's Avatar
matty675
rebuild it? its a seal. a simple replacement is all thats necessary.
replacing the rear main seal and rebuilding the engine HARDLY go hand in hand.
replacing the seal involves removing the oil pan, oil pump, and rear main cap as well as loosening the 4th and 3rd mains enough to push the top half of the seal out of the block.
rebuilding the engine would require complete disassembly, hot tanking, decking and rehoning the block. inspection and reconditioning of rotating assembly. new bearings and rings. line hone mains. inspection and reconditioning of heads. the entire valve train is usually replaced, however you may consider some of it salvageable.
Old May 3, 2011 | 06:35 PM
EHS22's Avatar
EHS22
I gotcha. Well, how much do you think it would be for a full engine rebuild?
Old May 3, 2011 | 06:48 PM
anywhere from 1500, to 50,000 dollars. just depends on what ya want.
Old May 3, 2011 | 06:59 PM
charlie1935's Avatar
charlie1935
$50,000 would be one helluva rebuild! Get a life time warranty with that?
Old May 3, 2011 | 10:11 PM
Seth_787446's Avatar
Seth_787446
Yea you don't rebuild the rear main seal just replace it. I just had a new radiator, front crank seal, oil pan gasket, and rear main seal done on my 5.9 for $570.
Now for $50k I sure want to know what's going on under the hood hahaha
Old May 3, 2011 | 10:56 PM
dhvaughan's Avatar
dhvaughan
you can replace the rear main for about $10 in parts. that's a lot cheaper than $50,000.
Old May 4, 2011 | 07:04 PM
EHS22's Avatar
EHS22
Yea i just want to replace the rear main seal. But im gonna have to take it somewhere cause i sure as hell dont know how to do it. Also, i just want the whole engine rebuilt with OEM parts. Not no 50,000 dollar deal. Haha
Old May 4, 2011 | 07:51 PM
J415's Avatar
J415
Not for nothing, but your all over the map. Why get your rear main seal replaced when you want to rebuild your motor? And why do you want to rebuild now? Is your motor busted?
Old May 4, 2011 | 08:40 PM
dhvaughan's Avatar
dhvaughan
read this, then you'll know how.
http://www.pavementsucks.com/tech-article-31.html
