shifting late hits rev limiter
Old May 15, 2011 | 09:57 PM
dodgeman2289's Avatar
dodgeman2289
Here ya go.
thanks.. a bit pricey... if i just replaced it with a new one how long would it take before it went bad again??
Old May 15, 2011 | 10:01 PM
The pressure sensors were notorious for becoming saturated, and not working properly, when the were new from the factory.......
Old May 15, 2011 | 10:05 PM
dodgeman2289
oh ok.. so this is one of the only solutions? has anyone on this form done it?
Old May 15, 2011 | 10:12 PM
MonteC, who had the trans thread, that is now archived in the FAQ section... (he seems to have fallen off the forums for quite some time now....) was a big advocate of these. Fixes one of the flaws of the dodge transmissions. (and that's where I got the part number from... his thread.)
Old May 15, 2011 | 10:13 PM
dodgeman2289
ok ill have to look into thanks!
Old May 15, 2011 | 10:34 PM
xjarhead69's Avatar
xjarhead69
Originally Posted by dodgeman2289
hey do you by chance know the link is to that silanoid. thing to fix my problem.. u said theres a gm version to fx my problem.
Here check this out its alittle cheaper. http://www.transmissioncenter.net/dodge.htm.
Its about 5/8 down the page.
Dodge "RE" Governor Solenoid to GM Pressure Control Solenoid Conversion Kit
#REC. This kit was specifically designed to handle higher base pressure in high performance applications and to improve the reliability of the governor solenoid in normal use. In performance units the pressure can flood the Dodge solenoid and cause a no shift condition at full throttle. This is the fix. Fits all rear wheel drive RE model transmissions. Cost $149.00 Qty 12345
Dave
Old May 15, 2011 | 10:54 PM
atthewmartin114's Avatar
atthewmartin114
idk how to drive auto so i cant really answer anything but to go standard. also i have to say ever one of there videos i watch either that gas light is already on or it comes on in the video. im going to have to assume that the saying" you cant fill'em because your always fixin 'em" is only said to me lol but i would have to say its time for a shift kit if your going to be in the tranny and all why not just do it up right and be done with it for good.
Old May 16, 2011 | 01:43 AM
dodgeman2289
ya my thought's exactly.. i was just thinking bout that if i have to replace that. and i was already gonna get a shift kit ill knock both out at the same time.. just as soon as i get the money for both.. i can drive my truck the way it is cause it only happens when im wot from 1st to 2nd. so i guess no more wot runs till i get shift kit and the new sensor..
Old May 16, 2011 | 02:15 AM
4085spd's Avatar
4085spd
You dont want that GM JUNK in your tranny. Newer larger unit Transtar part number 12432A or Borg Warner part # 50185. $46 plus the pressure sensor. Do both as the both work together.
Old May 16, 2011 | 02:40 AM
dodgeman2289
ya i was looking at the 146 one.. and the gm just looks alittle pricey and i dont like the idea of changing the inside of my dodge tranny to have gm parts in it.. ill prob go with the other one and i noticed they got something like a shift kit in there ill prob get both
