check engine light wont go off
Old May 10, 2011 | 07:14 PM
DirtRider1357's Avatar
DirtRider1357
Exclamation check engine light wont go off
my check engine light is on and ive gotten it scanned and it keeps saying "engine coolant temperature sensor high voltage". i just replace both the coolant temperature sensors and the light is still on. any ideas???
Old May 10, 2011 | 07:32 PM
Is the temp sensor working? Will the scanner tell you what temp the PCM thinks the engine is?
Old May 11, 2011 | 05:44 PM
oldspartan's Avatar
oldspartan
I just had to replace my temp sensor and wiring harness for it. That cured my CEL. Mine is also a 97 5.2 2wd.
Old May 12, 2011 | 05:44 PM
BigJBones's Avatar
BigJBones
Cool
Ay, isn't this where your supposed to reset the computer? The whole disconnect the positive cable from the battery thing.?.?.?
