Gears came in, where to get speedo reset?
I'm confused? if you use 4.88 gears with 38" tires the drive ratios will be equal to stock resulting in no need to change any speedo gears or pcm mods.. Unless I'm missing something? its only when using tires or gears that are mismatched with each other that will cause your speedo to be off?
On the 98? and up trucks, vehicle speed is determined by the sensor on the rear diff, it reads a tone ring on the carrier. Gear changes will have zero effect, as the tone ring is still reading the same number of CARRIER revolutions. Tire size WILL have an effect, as you are changing distance traveled per carrier revolution.
