oil drops at low rpm.. possible solution?
Old Jul 9, 2014 | 12:33 AM
  #21
AtomicDog's Avatar
AtomicDog
Originally Posted by DodgeTheDadRamTheDaughter
I would not go with a high volume oil pump if you do not have a high capacity oil pan. The pump will suck the pan dry and then you'll be regretting it.
Unless you are spinning the motor like you are at NASCAR race for 200 laps, you will certainly not run the stock oil pan dry by using a high volume oil pump. This is a myth. Besides, the percentage increase in volume is only a max of 25% on a good day, since the oil pump pickup tube has not been increased in size.
