oil drops at low rpm.. possible solution?
ok so when i come to a stop my oil pressure gauge drops to 40 or 0
then goes bk up when hitting the gas
i found a solution maybe online
i was wondering is.. if this is possible in dodges?
http://www.techsupportforum.com/foru...es-250551.html
Our gauges aren't known for being the most accurate. It could be the gauge but at 260k it wouldn't hurt to change the oil pump. It'll cost like 75 bucks. The pump is around 30, oil pan gasket is 30, and oil and filter. At least then you know it's not the pump. If you change it make sure you prime it first.
i understand that the pressure changes as the RPM's do but when my truck went from 40 at speed and 0 at idle it was the main bearings getting eat up. when you drop the oil pan you really need to go through the oil you drained out and the sludge that is built up in you pan and see if you find any METAL AT ALL. if you have some then it is time for a rebuilt. sorry for the bad news but a rebuild is cheaper than a new truck.
Trending Topics
I evidently didn't read the first post all the way thru. I didn't see the dropping to 0.
That damn sure ain't right.Guess I get 30 lashes with a wet noodle for not paying attention.
well i figure when i do infact drop the pan ill be:
cleaning out the oil pan of all sludge
cleaning and rebuilding the pump (if its in working condition)
checking the pickup line
cleaning the "sump"
and checking for metal shavings
if i need to rebuild anything.. itll just take longer :P
but thats the benefit of working on my own vehicles
learning
cleaning the "sump"
learning
Took me about 2 hours to drop the pan, and change the pump the first time....
