Plenum welding
Old May 23, 2011 | 02:55 AM
  #21
tweeker909's Avatar
tweeker909
Make a pan with no holes then weld it. No point what so ever to even mess with bolts if your going to weld it. Milling the manifolds pan surface will not effect anything. Bolts being to long is a myth but thats not the topic at hand.
Old May 23, 2011 | 05:53 AM
  #22
kejobe's Avatar
kejobe
I see your point, but i already have the hughes sitting on my toolbox. Been there for a few weeks now. I just need the rest of the parts and more importantly the time to do it. And the longer it sits there mocking me as i keep adding oil i keep thinking of other parts to get or this whole welding it on deal.
Old May 23, 2011 | 07:08 AM
  #23
Novarider's Avatar
Novarider
Can you weld the stock plate to the manifold with the stuff in that video?
Old May 23, 2011 | 08:18 AM
  #24
I wouldn't trust welding thin steel, to aluminum.
Old May 23, 2011 | 09:04 AM
  #25
kejobe's Avatar
kejobe
Well, i guess im just gonna bolt it on. Machinest here at work says hes not that good at alum. One last question, is the all metal gasket supplied by hughes any good? Seems odd to put steel between alum.
Old May 23, 2011 | 09:43 AM
  #26
I went and bought a good fel-pro gasket to go in there.
Old May 23, 2011 | 10:27 AM
  #27
kejobe's Avatar
kejobe
How long ago did you do it and hows it holding up?
Old May 23, 2011 | 12:06 PM
  #28
couple months ago, and a thousand or two miles ago. So far, the truck runs great. (given the amount of money I have sunk into it...... it certainly should....) No evidence of oil in the plenum.
Old May 23, 2011 | 12:08 PM
  #29
kejobe's Avatar
kejobe
Ill probably get the fel-pro then. Thanks.
Old May 23, 2011 | 12:23 PM
  #30
Novarider's Avatar
Novarider
If the fel-pro worked better wouldn't hughes use it? Considering they call it a permanent fix wouldn't they have tested the gasket it comes with?
I'm not saying anything bad about anyone I'm just curious why you feel the fel-pro gasket is better
